Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 03-03-2009, 01:06 PM
Default Best 48 IDA Intake for 302 with thermostat housing
I need some help. I am new to the IDA. I have over the last few weeks been able to acquire three of the four good 48 IDAs that I will need, but need to get an intake and linkage. I have a 302 that is now a 347. I want an intake that has the thermostat housing cast on it.
So I have three questions.
1. Who's intake for the 302 with thermo housing is the best and allows for linkage... Blue Thunder or... ?
2. Who's linkage should I use?
3. Who should I go to to buy the intake and linkage?
Thank you in advance for the help!
Mark
Old 03-03-2009, 01:20 PM
www.piercemanifolds.com
Hope this helps.
Old 03-03-2009, 01:33 PM
Hope this helps.
It looks like their linkage kit is a stand alone kit and does not attach to the manifold anywhere but at the carb mounting locations. Is this the best way to do it? I have also seen others that have a threaded boss in the center of the manifold.
Old 03-03-2009, 02:00 PM
bobcowan's Avatar
This is exactly what you're looking for. It has the boss for the central throttle linkage, like the originals. It even has vacuum passages cast it.
http://verycoolparts.com/Stack.htm
Old 03-03-2009, 02:42 PM
That one says that it is for EFI. Their carb manifold for the 302 does not look like it has that boss or the vacuum passages.
http://verycoolparts.com/weber.htm
Old 03-03-2009, 04:33 PM
bobcowan's Avatar
Should be the same. The stack EFI systems are built to emulate the webers. I'm using a carb manifold from Blue Oval with my EFI system. Call wayne and ask him.
Old 03-03-2009, 04:39 PM
Sorry... but Wayne is from VeryCoolParts?
Old 03-03-2009, 05:10 PM
bobcowan's Avatar
Yeah, sorry. Wayne Presley, owner of VCP.
Old 05-25-2009, 09:16 AM
It looks like their bond kit is a angle abandoned kit and does not attach to the assorted anywhere but at the carb ascent locations. Is this the best way to do it? I accept aswell apparent others that accept a threaded bang-up in the centermost of the manifold.
_________________
Thermostat
Old 05-25-2009, 09:18 AM
_________________
Thermostat
Old 05-29-2009, 08:04 AM
bobcowan's Avatar
I'm sorry, but I don't understand the question. Angle Abandoned? Carb ascent locations? Threaded Ban-up?
Old 05-29-2009, 12:26 PM
Banned
fuji is either a troll (2 posts), is challenged by the English vocabulary (aren't we all?) or has a grasp on advanced engineering concepts that us mortal beings will never fully understand.
Old 05-29-2009, 08:24 PM
zrayr's Avatar
Cobra Make, Engine: Fords
you might be correct on all three observations.
Z.
'65 K code Mustang
'66 Galaxie 500
