10-16-2002, 05:05 PM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
cdog,
I use new Fel Pro gaskets and high temp sealer on both sides if its already had gaskets.
The best method for a new header is to use only the high temp sealer and no gasket, once a gasket is used the flange warps and you are forced to use a gasket, then its hard to get a permanent seal.
Scott
