Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
  #21 (permalink)
Old 03-18-2010, 08:54 PM
jdean's Avatar
Can't go wrong with a 460 stroker following advice of Paul Kane and Scott Johnston. They know their stuff. They both helped me a bunch with my 521.
6th generation Texan....
  #22 (permalink)
Old 05-13-2010, 10:57 PM
Registered User
Cobra Make, Engine: 67 Shell Valley - Kevlar; 514:TKO
Send a message via AIM to Jahred
No mention of fuel system. What did you use? I recently talked to performance shop owner that laughed when I told him I was running a Holley Blue in my 514. Now I'm confused. Cause he was right. On the strip it dies at 4500 to 5000 RPM. He suggested the bowls on my 1050 are NOT getting filled. I'm stil not sure I'm not short air ..... but curious about your air/fuel system, cause ...... really ...... physics is physics..........
  #23 (permalink)
Old 06-23-2010, 04:25 PM
jetsbaby's Avatar
Originally Posted by Jahred View Post
No mention of fuel system. What did you use? I recently talked to performance shop owner that laughed when I told him I was running a Holley Blue in my 514. Now I'm confused. Cause he was right. On the strip it dies at 4500 to 5000 RPM. He suggested the bowls on my 1050 are NOT getting filled. I'm still not sure I'm not short air ..... but curious about your air/fuel system, cause ...... really ...... physics is physics..........
I am using an Aeromotive A1000 pump with their fuel pump controller for street use..The controller does not let the pump kick in to full capacity until 3000 RPMs..Works great..
  #24 (permalink)
Old 06-23-2010, 07:50 PM
Cobra Make, Engine: SPF #298 427 FI
keep us posted on the slave and clutch set up I am curious if you can achieve the .250 clearence Mcloed recommends with the fortes slave kit.
  #25 (permalink)
Old 06-23-2010, 09:05 PM
jetsbaby's Avatar
Originally Posted by mpanten View Post
keep us posted on the slave and clutch set up I am curious if you can achieve the .250 clarence Mcleod recommends with the fortes slave kit.
It was very easy to dial in..No problems..I am driving in gel coat and the clutch is great..
  #26 (permalink)
Old 06-24-2010, 09:38 AM
jetsbaby's Avatar
  #27 (permalink)
Old 06-25-2010, 07:30 AM
Default 557 bbf w/ps & ac
  #28 (permalink)
Old 07-04-2010, 09:58 AM
PANAVIA's Avatar
Don't forget to put in a pcv valve !
Nice looking setup , I dig the late model alternator
Steve
  #29 (permalink)
Old 07-07-2010, 04:28 PM
jetsbaby's Avatar
Steve
Nope no PCV valve..I have read that several people have had problems with a PCV on a stroked 460..The more air it can breath the better..
Rate This Thread:
