09-24-2012, 02:27 PM
Spal Cooling Fan 30102113
Has anyone had experience using this high output fan. It has impressive performance data, but it notes that it is only recommended for paved track useage. It is not recommended for dirty or wet environments due to no sealing features. I am curious if they are on the money or over the top on their disclaimer. If anybody is using this fan, please let me know your experience. Thanks
10-01-2012, 07:19 AM
ga
Cobra Make, Engine: EM 466 Ford aluminum Blue Thunder heads
I use 2 10" versions of this fan for more sq/in coverage. 10 months now, I have been thru rain but no real dirt or dust. Drive every w/e and AutoX.
Atl. set an all time record high this past summer of 108. I took the car out to see what would happen and I withered but the car has never overheated. Running a warmed up 460, alum rad.
10-01-2012, 10:28 AM
Thanks for the feedback. I too am running a 460. I aquired another new fan manufactured by perma Cool. It has the same CFM (Approx 2400). The Perma Cool fan has a sealed motor and aluminum blades. It is a little bigger front to rear. I am still in a decision mode. Thanks again for the input.
10-01-2012, 05:16 PM
IL
Cobra Make, Engine: Shell Valley Cobra Kit -428 Fe Built by Clayton Racing Engines
Take a look at the early Viper fans , they have small rubber flaps on all four corners that allow air to flow threw at road speeds and close at low speeds to force more air threw the fan . It is a two speed unit . I believe it is 2600 at low speed and 3400 CFM on high.I trimmed the factory mount and it slip right in . I have use it for five years and works great . You need two relays and an over ride switch and run it direct from the Alt.
10-01-2012, 09:25 PM
Cobra Make, Engine: ERA154 427 HR
This will do the trick.....
Taurus Cooling Fan Install
I have it, it sucks so much on high, you can feel the suction through the front opening!
10-02-2012, 06:58 AM
Go with the Taurus fan and proper wiring set up. End of heating problems, my car has been running cool in temps. up to 120 degrees here in the desert, and that's no bull.
Failure is not the outcome, it's not trying.
05-03-2013, 07:21 PM
SPAL has some dual deep dish fans that would work even better than what is in the '30102113" -- Steve
05-03-2013, 09:00 PM
by all means the taurus or a mark viii fan, spal makes a controller for them that is pretty trick you can set on off temps.
you can pick up used fan assemblies in the boneyard, google it you'll see dozens of how too's on the subject
Fred B
05-04-2013, 09:04 AM
Ut
Cobra Make, Engine: 66 Cobra
I believe Kirkhams uses Spal fans on all their cars.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
05-05-2013, 07:04 AM
The Spal controller has been know to fry with the Taurus fan, too much of an amp draw on high speed for the controller's internals.
Hollister road's setup is what I use. With it you can have two temp sending units that bring the low speed on at 180 deg f and the high speed on at 195 deg f. I've used it for years without a hiccup.
Classic Chevy Truck Parts 47-59, Mark VIII Fand Relay Kits
Too many toys?? never!
05-05-2013, 08:20 AM
Cobra Make, Engine: RUCC, SB 331 Stroker
I did the Taurus fan installation about a year or so ago and used the 2Sp controller from this company: Welcome to Delta Current Control. It has performed flawlessly.
05-05-2013, 09:34 AM
good to know UNDY, thanks.....
Fred B
