| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
07-11-2006, 03:09 PM
NY
Cobra Make, Engine: Superformance, FRP460 Big Block
Decceleration backfire but only RH side
Hi all,
This just started happening on my SPF/460, and not all the time. It all started when my RH sidepipe support bracket broke (common, I'm told) welded it, broke again, finally welded a bent rod "spine" under it. My collector bolts were lose so I attempted to tighten as best I could. It's really tight in there. No breaks so far, but the backfiring has started. Only as I lift off on the throttle as I shift to the next higher gear.
Is this air getting into the exhaust? Do I have to redo the manifold gasket and collector gasket? Is there a quick fix?
Thanks
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
07-11-2006, 03:20 PM
FL
Yo Ray,
Nine times outta ten it's an exhaust leak. Extra oxygen gets into the exhaust flow somewhere after the exhaust port and mixes with the unburned fuel. Happens on deceleration. BOOM!
Figure out where it is leaking and tighten or replace the gasket as required. I always try tightening first (don't overdo and break something off).
Seems to be a common Cobra disease caused by vibration and heat
Tom
07-11-2006, 04:25 PM
Ca
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Or, just do like I do with my beater Porsche 912 whose exhaust system is just barely attached to the motor...
...Tell anybody who looks at you funny that the noise is due to the severe valve overlap of your full race cam dumping raw high test fuel into the hot exhaust.
Sounds very impressive, and requires almost no work on your part.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
07-11-2006, 05:35 PM
TN
Cobra Make, Engine: SPF, 418 Stroker
Ray - I agree with Tom. It's probably air getting into the exhaust, and from what you said, probably from a loose collector flange or a blown collector gasket. Because of heat and stress cycling, those bolts get brittle pretty fast and are easy to break. Some people have reported good luck with stainless steel bolts for this application. I had the same problem as you and replaced my bolts with grade 8 bolts with double nuts. So far, so good.
Hope this helps.
07-11-2006, 06:18 PM
QLD
Ray,
Just gone through the same problem with my EFI 302 motor.
Slight loss of power associated with a misfire when changing gear (heard through one exhaust only).
Replaced exhaust intake gaskets and plenum gasket and cleaned injectors - now running as it should.
Problem with mine was that I don't have a diagnostics plug on the engine resulting in a fair bit of searching to find the cause.
Air getting into the exhaust results in a lean engine which is over compensated by the fuel mixture thereby producing the misfire and excessive fuel usage (no longer cheap in Ozzie land)
Good luck mate
PCC (Peter Craig)
Keep the sun shining
07-11-2006, 06:24 PM
FL
Hi CWizard,
Sorry but I need to disagree about the stainless hardware. Every time I've used those, they break off. And if they don't break, they seize so you can't get 'em off without twisting them off.
There are regular steel bolts made for collectors' exhaust temps and acidity that are reusable, and re-tightenable (is that a word?). I use those.
I prefer the Stage 8 header locks, too, while I'm recalling hardware specifics. I tried the Breslins, but they tried to ruin my aluminum heads' threads, and a couple of their allen screws which were supposed to lock them on, fell out!
Either bolt style is hard to install unless you are plastic man, but the Stage 8s seem to hold fine for me.
Tom
07-11-2006, 06:31 PM
NY
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
backfire on deceleration
Ray..this also happened to me.
On the side of the backfire you need to check
intake manifold gasket,
header gasket to cylinder head,
header flange gasket to exhaust pipe.
One of these gaskets will all cause the backfire
Mine was the intake gasket !!
Tony
07-12-2006, 04:29 AM
NY
Whew! Intake gasket would be easy enough although it could get expensive as it would be the best time to go for that twin 4bbl kit that is available from Carl's Ford Parts for $1695
I guess the thing to do is to re-tighten up first. I don't think it's been re-done after break in anyway. Anyone have torque specs on manifold bolts, intake and exhaust?
Thanks for all the replies. I'm dreading the flange gasket replace ordeal.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
07-13-2006, 12:52 PM
Cobra Make, Engine: SPF#131 520 cubes; 650 HP
A new header to sidepipe gasket/collector gasket and ALL NEW Grade 8 STEEL nuts/bolt should fix you right up...
When your hanger broke, the pipe weight, along with the loose bolts to the headers/collector probably tweeked your gasket and retightening would no longer be a good "fix"....
Shooter...Looter...Not Neutered.
07-13-2006, 04:08 PM
TN
Tom - Thanks for the info. I'll have to try some of these next time I change out the collector bolts.
07-13-2006, 06:25 PM
NY
Thanks Tony,
I'll call Dennis tomorrow and order them. I have to talk to him about installing the steel baraided brake lines I got from him. I can't get the old lines off the Wilwood calipers. I think they epoxied the originals in there.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
07-13-2006, 06:50 PM
NY
Ray
I would have to agree with PJS50, since your rear sidepipe bracket broke and the flange bolts were loose, change that gasket and you should be all set.
I have one gasket if you need one in a hurry !!!
Better that then the intake !!!
Tony
07-14-2006, 06:31 AM
NY
Thanks for the offer, Tony. I won't be able to get to it until next week anyway so I'll just order from D.O. I also ordered some new nuts and bolts from Jegs.
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
09-18-2006, 06:57 AM
Ray,
When you had your headers/sidepipes apart, did you look at the header flange to see if any of your individual cylinder pipe ends had cracked at the flange junction? I found a couple of cracks there that I had welded up when I did a rebuild... That can also be a source for air in your exhaust
I assume your sidepipes were fine at this same location if you filled in that recess with that Wurth material...?
Pat
09-18-2006, 07:52 AM
NY
Originally Posted by PJS50
Ray,
Pat
Good thought, Pat.
As I recall, however, they were in pretty good shape, except for that concave center section. But you're right, I may have to look closer where they meet in the center.
Thanks
Ray
New York
SPF#1052 11mpg
'08 Volvo S80 18mpg
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
