Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 04-19-2007, 12:01 AM
Default 572 Stroker Power
I just finished a 572 stroker based 460 motor. I am curious about the power and torque I should expect of this motor. I am new here and have enjoyed reading the many amazing insights this family has expressed regarding the 385series Ford motors.
Here are some specifics about my motor:
1) 850 cfm Mighty Demon Carb with 1 " spacer
2) Weiand Stealth CJ intake port matched to cyl heads with plenum divider knife edged.
3) Factory iron CJ heads(DOOE-R) with new undercut stem valves, hardened exhaust seats, thermactor bumps removed from exhaust ports and mild pocket porting on both the intake and exhaust pockets
4) 254/264 duration at 0.050" lift with .605" lift using 1.8 ratio roller rocker arms--hydraulic flat tappet cam.
5) 11.25:1 compression ratio
6) 1 3/4" primary full length headers to 3" collectors and 3" exhaust pipes.
Any guesses on HP and torque at given RPM's?
Any input would be appreciated.
Thanks in advance.
Don
Old 04-19-2007, 05:23 AM
I'm assuming a 4.5" bore and a 4.5" stroke with this combo. Engine Analyzer Pro is showing about 550hp @ 5500 rpm and 600 lb-ft at 4000 rpm.
Your heads and cam are a real bottleneck to this engine. There's just not enough there to feed 572 ci.
I have a feeling that with a set of Kaase/Ford Racing SCJ heads and a large duration roller cam, you could see 700-750hp pretty easily.
Old 04-19-2007, 12:39 PM
Thanks for your input. Right now, my budget limits me to the conservative hydraulic flat tappet cam and DOOE-R heads. Down the road, however, I will be looking at an upgrade of the intake, heads and cam. What specs of a roller cam would put this motor in the 700-750 hp range? What kind of cost would be involved by switching to a roller cam and lifters?
P.S. The bore and stroke are 4.5"x4.5" as you guessed.
Don
Old 04-19-2007, 01:17 PM
Tom Wells's Avatar
Don,
http://www.460ford.com/index.php
Enjoy,
Tom
Old 04-19-2007, 02:00 PM
I've built Windsors and I've built FE's, but I've not built a 385 series engine yet. Tom's suggestion of hopping onto the 460 forum would be a good one.
Roller cams and lifters will probably add $350-400 to your bill, but it's all for a very worthy cause.
Lots of duration will help that engine breathe, but it will also move your powerband up higher. I assume you're putting this in a Cobra, so the light weight will help you here.
My guess is that a cam with a duration at .050" in the 270/280's range with a lift of about .700-.750 will get you there if the head flow is good enough to back it up.
When you get to the cam-purchasing point, you can give Keith Craft a call and he could point you in the perfect direction.
I know all about budgets...I had to make a lot of shortcuts on my 428....but they're fun just the same. You can always save your pennies and add on later!
Old 04-19-2007, 11:54 PM
Actually, this motor is going into a restored 1977 F-100 SWB 2WD truck. I do have a dream of having a powerplant of this size in a Cobra in the future. Thanks to each of you who responded.
Don
Old 04-20-2007, 09:25 PM
Don
These engines love to make power. In a previous job I had, we ran some big cubic inch Fords and they never disappointed us.
Also looks like you are using every bit of cfm of your carb, but unless its strickly a race engine, I wouldn't worry about it too much. When we watched the A/F - BSFC when pulling over a carbs cfm, they tend to go rich a little.
Old 04-25-2007, 01:35 AM
Thanks for the neat dyno graft. I will "uncork" this stroker beast ASAP with the use of deep breathing heads, lg single pane intake and large duration roller cam as soon as possible.
Don
Rate This Thread:
