  #41 (permalink)
Old 12-12-2011, 07:41 PM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
Maybe more interesting is how that weight is distributed
LF wheel 249.4kg
RF 233.3kg
LR 216.4kg
RR 238.1kg
split 48.49% front
51.50 % rear
Ross
  #42 (permalink)
Old 12-18-2011, 10:18 PM
2FastCobra's Avatar
Cobra Make, Engine: FFR with Dart Iron Eagle 408w motor with AFR 225 heads and 83mm turbo, 924rwhp, 986rwtq
My FFR is 2,270 with a little less than a quarter tank of gas. I have a 408w motor and single turbo. My last dyno was 924rwhp/ 986rwtq at 18.3 psi.
  #43 (permalink)
Old 12-19-2011, 04:00 AM
Sawdust's Avatar
SPF #1950, 402R, TKO600, 1/2 tank of gas, 2650lbs. Weighed on a certified scale.
Stu.
  #44 (permalink)
Old 12-23-2011, 10:23 AM
Sminor's Avatar
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
Shell Valley- 428 Aluminum Heads, Dual Quads- Ford 9"- Halon- Carpet- 1/2 tank of gas- 2492#s. 46% front, 54% rear. Around 1% difference left to right.
  #45 (permalink)
Old 12-23-2011, 06:03 PM
BAsque1's Avatar
2850lbs+270lb driver + and additional 56lbs with 1/2 a tank.
427 S/O 520hp. 5sp Doug Nash
  #46 (permalink)
Old 12-23-2011, 10:30 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
Here is when we scaled mine, I thought it was a tank but it seams to be average.
Those numbers are from a fresh build I did no adjustments to get those numbers.
Patrick
http://www.clubcobra.com/photopost/s...0&ppuser=23754
Well, it occurs to me that perhaps not all of the modifications I made are technically 'street legal'
Nothing good ever happened after this statement;
Hey Moe watch this!
  #47 (permalink)
Old 12-27-2011, 06:44 PM
DougD's Avatar
Originally Posted by AMiller View Post
Mine was weighed on certified by the state scale. That alone should make you wonder????
Aaron
It depends on what that scale was intended to weigh.
Those that use scales intended to corner weight a race car can be reasonably sure that they are accurate. The scales were designed to be accurate in the range in which a Cobra's weight falls.
Those that use scales intended to weigh loaded trucks weighing many, many tons should not be so reasonably sure. A relatively light weight Cobra is at the extreme end of their measurable range, and accuracy at the extremes is suspect, especially when comparing a few hundred pounds' difference.
It would be interesting to gather a cross section of manufacturer's Cobras and weigh them all on the same scale.
Anyone know the advertised curb weights of the original Mk 1/2 and Mk 3 Cobras?
  #48 (permalink)
Old 12-27-2011, 08:47 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
backdraft car #260 with a alum. headed 302, t5 and 15 inch biscuits...2450 with 1/2 tank of fuel on a truck scale
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
  #49 (permalink)
Old 12-28-2011, 05:52 AM
G-Pete's Avatar
Aaron
Well Aaron, there is a pretty easy method to check that.
Before you go and weigh your car, weigh your self at home in the same outfit you leave the house. Weigh the car with and w/o you - if the scale says the same she is good. If there are 20 pounds differences - leave and look for a different scale.
Today the bathroom scales are pretty accurate.
(The same applies to corner scales, where you can put yourself on)
DRB GT40 MK1 red #49- sold
SPF 2063
  #50 (permalink)
Old 12-28-2011, 08:50 AM
lamaluv's Avatar
At Reno-Fernley during WSCB as weighed by WKW Racing my car w/o driver and full tank was LF644-RF713-LR677-RR657 for 2691 total weight. 428FE with top loader, Jag rear w/inboard brakes, scatter shield, fuel cell with skid shield etc. Ready to race with my fat a** included the weight ratio was 48.68% front & 51.32% rear.
Just curious, do any of you with those morbidly obese Cobras ( over 3,000lb) have problems spinning the tires or out accelerating most every other car on the road.
Dick
