Like Tree1Likes
  #21 (permalink)
Old 01-19-2014, 03:14 PM
Originally Posted by Dumpling View Post
2) it has a big "PATENT PENDING" graphic on the website...what exactly can they patent? Especially given the example posted above.
You don't have to have anything patentable to have a Patent Pending.
  #22 (permalink)
Old 01-20-2014, 04:56 AM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
I wonder if it would be more stable if you used them perpindicular to the rails as opposed to parallel.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
  #23 (permalink)
Old 01-20-2014, 07:20 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Thanks to everyone has or will post. I've go an inquiry in to the manufacturer to see if any have been delivered to my neck of the woods so I can see one in action and get an idea if there are any potential problems with clearance or positioning.
I'll post an update when I hear back from them.
DonC
  #24 (permalink)
Old 01-20-2014, 10:14 AM
Bernica's Avatar
Senior CC Premier Member
They are advertising in my latest Hot Rod magazine with a pic of a black Cobra up in the air.
  #25 (permalink)
Old 01-20-2014, 08:42 PM
DonC's Avatar
Dumpling:
Quick calculation on spacing between wheels with tires mounted. I run 275/40/17 fronts and 315/35/17 rears both of which have a posted diameter or 25.7". Given a 90" wheel base that puts the distance between the back of the front tire and front of the back tire at 64.3".
On paper, it should clear but that's purely theoretical. Still waiting on more information from the manufacturer.
DonC
  #26 (permalink)
Old 01-21-2014, 03:45 AM
Cobra Make, Engine: CR Cobra 3169
In the video it looks like the support block is under the floor pan. Not a good idea on some cars. What happened to the old exhaust lift bag idea.?
Lift one side, place the jack stands. Then the other side. I would not get under the car wrenching on a big suspension bolt with this system.
JD
  #27 (permalink)
Old 08-04-2014, 10:02 AM
Voyager's Avatar
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Does anyone have firsthand experience lifting their Cobra with one of these PendPak QuickJacks? Understand a 5000 lb version is going to be released soon. Would be nice in the tight confines of my small garage.
  #28 (permalink)
Old 08-05-2014, 03:47 AM
mdross1's Avatar
Originally Posted by Snake2998 View Post
I think the posters here are being overly critical re the security of these, as I doubt that they are any more prone to collapse from sideways pressure than ordinary jack stands and most of us petrol heads have survived many hours under cars on jack stands doing some very heavy spannering.
That said I would certainly add jack stands at the corners of the car to the mixture if I were to use them and crawl under the car.
Also - they are portable and ideal for confined workspace where four poster lifts are obviously not, so I rather like them and would certainly buy them but think they are too expensive. Might think of making a pair with a manual hydraulic pump some time though.
I'm with you Snake and would have no problem crawling under our car on this lift after satisfying that need to know like we all have some more than others.
  #29 (permalink)
Old 08-05-2014, 08:00 AM
Senior ClubCobra Member
I don't know how to calculate the strength of the tubing. But at 3500 lbs, each tube is only holding up 440lbs.
As for the bolts shearing, if they were 1/2" grade 8 bolts, each one is good for 17,000lbs.
  #30 (permalink)
Old 08-11-2014, 04:07 AM
BAsque1's Avatar
I am very concerned about the SAFETY issue, I am OCD if not anal about safety . While I have limited garage space I would not risk being crushed by my own car. I don't have the room available for a 4 post lift so I have to do it the old fashioned way one side at a time and jack stands.
Lou
Basque1
Display Modes
