| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
03-10-2016, 07:14 AM
Registered User
Trunk lift
I want to swap out the stock mechanical trunk lift bracket for something better. Maybe a gas shock. Has anyone used a gas shock and can recommend which to use? I'm thinking it may be better to use one on each side to minimize the chance of stressing the fiberglass.
03-10-2016, 07:23 AM
AR
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I have been thinking about it. I did it for my hood and it worked out great! I'm going to try to hide mine so the shocks will not be visible.
Larry's Home Page
03-10-2016, 12:35 PM
I have repaired three trunk lids from gas Springs damage.
All of them had the spring pressure on the trunk when it was closed
Too much Pressure trying to open the lid when it was closed
One had two springs on it and it actually cracked the deck lid
And one ripped the latch out of the inner panel so be careful
you want a spring with just enough power to lift the deck lid and make sure it's set up with the lid is close there was no pressure on it.
Google gas springs and you can find a diagram how to set them up ( mounting points)
Tom
03-11-2016, 05:47 AM
VT
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I use a single gas strut mounted on the driver's side. Got it from: McMaster-Carr
You need to go as low pressure as you can. I've forgotten what I went with but it took a couple of iterations to get it right.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
03-11-2016, 07:19 AM
Registered User
Good info. Thank you very much!
03-11-2016, 07:38 AM
PA
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Just out of curiosity, what's the problem with the mechanical lift bracket? They work well - at least mine does, a little grease on the ratchet mechanism once a year and it will probably last indefinitely and they don't stress the fiberglass when closed. Gas struts tend to weaken over time... Just trying to understand the attraction to changing this.
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
03-13-2016, 05:24 AM
Q
I really like the discreet little struts that Absolute Pace are using on their cars.
https://m.facebook.com/AbsolutePace/...pe=3&source=42
Craig
03-13-2016, 05:00 PM
VA
Cobra Make, Engine: West Coast Dreams
gas struts
Take a look at the lid mounted bracket. The shape allows the strut to apply no upward pressure to the fiberglass lid.
03-13-2016, 05:54 PM
SA
Cobra Make, Engine: CR Cobra 3169
I like the gas strut. I started of with the catch type, until someone came along and tried to shut the boot without releasing the catch. Almost cracked the lid. I've now fitted it to the bonnet and I hate having to go around the other side to release the catch or fiddling with the catch having to lift the bonnet press the catch then drop it. I have heard that someone who re-gasses these lifts can adjust it to any pressure you need. So I'll be looking to replace it soon. The boot is so light you only need a very weak strut to hold it up so when it's closed there isn't much force on the brackets. I've made up a slightly longer bracket on the lid itself to spread the load.
JD
03-13-2016, 06:08 PM
SC
Who's kit do you have?
03-14-2016, 06:40 AM
Member of the north
Cobra Make, Engine: A Cobra
Larry - I like what you did.
I have like over 10 years of "road" and have been looking at Spats.
Nice job on the Cruise Control and gas struts.
Tru
03-15-2016, 02:07 AM
WC
Cobra Make, Engine: Shamrock
Neat installation - just remember gas struts should always be installed with the main body on the top side and not like you installed them - unless those are special struts??
See here:
Gas Spring Mounting Instructions | Industrial Gas Springs
03-15-2016, 07:03 AM
Ouch Ouch Hot Sand
FL
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
I'm at this point now and trying to decide what to do and since I don't have any trunk or hood supports I can go in any direction...........
Safe Flyin, errrrr Drivin, Earl
02-26-2019, 11:50 AM
FS
Cobra Make, Engine: Backdraft RT3
Reviving an old thread. I replaced my Backdraft’s mechanical strut with a Monroe Maxlift gaslift. It fits perfectly and I reduced the pressure with the grub screw to just enough to hold the bootlid up...
