| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
8Likes
02-29-2016, 01:18 PM
CA
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Door Sill Plates
Did the originals have them? I bought a shrinker/stretcher tool from Woodward with the hopes of fabricating a set. I tried 5052 and 6061 in .040 thickness with the sides at 1.00 inch wide and .50 inch wide. All four attempts resulted in the stretched section breaking.
Does anyone make them to fit the 289 FIA door shape or should I pursue a different solution for the edge?
Thanks
Bill
02-29-2016, 01:42 PM
Cobra Make, Engine: SPF 289 Street
You need softer, un-heat treated aluminum. 6061 cracks when bent, stretched.
02-29-2016, 01:43 PM
AZ
I'm not a Smith by anyone's imagination but I'd say the aluminum would most likely need to be annealed before stretching. Google it and you'll see more about the process.
Alba gu brąth
02-29-2016, 01:55 PM
Club Cobra Member
OH
Cobra Make, Engine: A&C 427S/C, 351W, T5
I bought angled aluminum from either Home Depot or Lowes and made my door sills.
I used a bit of heat on the bend drilled and csink the holes. Looks great.
02-29-2016, 02:06 PM
CA
Pnjsnak-
Thanks for the alternative. Do you have pics?
Bill
02-29-2016, 02:09 PM
AZ
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
I recommend 5052 aluminum for forming. 2024 will also work.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
02-29-2016, 02:14 PM
CA
I tried 5052. It broke also
02-29-2016, 03:54 PM
AZ
Itbites, Good to see you are still depleting our oxygen. Please drop me an eMail, kbebout@yahoo.com
Karlos
Karlos
02-29-2016, 06:54 PM
Club Cobra Member
OH
No pics available she is undercover sleeping the winter off.
Just check out the aluminum stock at Lowes or Home Depot
The 1 x 1/2 stock is 36" lg
Put a flame to it and it becomes pretty maluable and easy to form the radius at each end
02-29-2016, 07:30 PM
MA
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Hi Bill,
The bodies are made from 3000 series ally. Very soft and formable. I wouldn't doubt that the trim plates may have been too.
Good Luck,
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
03-01-2016, 10:36 AM
NH
Comp cars did not have sill plates that I know of.
However on my old car I too used the flat alloy stock from Ace Hardware, same as Lowes, it bends and conforms nicely.
All for about $6, rivets extra.....
03-01-2016, 11:11 AM
CA
85CCX-
I've been bending bending section 36" x 2" into 1" x 1" 90 degree sections, then stretching one side so as to follow the contour of the door and protect the edge. When I try to make the sharp radius in the front, the stretched part cracks. I take a picture and post. If it's just a flat piece, I wouldn't have any problems
03-01-2016, 11:15 AM
CA
03-01-2016, 12:49 PM
MA
Looks like you're using some very thin stuff. Thicker material should give you a little more stretch before it splits.
MK.
-J. James
M. Krause
1.508.944.3368
03-01-2016, 04:07 PM
NH
Awesome job!
Looks like you on track.
03-17-2016, 05:40 PM
CA
I successfully made two sills today. Many thanks to everyone that provided excellent feedback and suggestions. I used .040 3003-H14 aluminum, 2" x 36". I made a lip 1/2 wide and proceeded to stretch and shrink to fit a buck I made from the contour of the body. I cut a piece of the carpeting that came with the kit (I won't be using it anyway) to check gap between the lip of the sill and carpeting. Body needs some trimming. Easy stuff
03-17-2016, 06:07 PM
AZ
Nice job!
Alba gu brąth
03-17-2016, 06:10 PM
NH
Fabulous!
Great work, proud of you.
03-17-2016, 06:31 PM
NY
Cobra Make, Engine: Contemporary 302 Ford stroked to 347
Great job
Ed
03-18-2016, 12:14 AM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Bill , it looks like your using the grooved jaws that came with your shrinker/stretcher, there is an outfit in the USA somewhere that remove the grooves and apply a 'stippled' finish for use on alloy, does not mark the alloy as much and therefore eliminates the tendency for the alloy to crack on the grooves.... gitzit or something like that...
Jac Mac
