07-17-2016, 01:41 PM
Cobra Make, Engine: Everett Morrison
Misfire with Jumpy Tach
This has me stumped..
They key is the jumping tach, seems like a primary ignition problem. Under load the car misses. Seems to be at its smoothest while at 3k, but once back under load it misses again. The tach jumps 1-2k either way. Wiggled all grounds at idle, no change. The cap has had pitted terminals for a while now, but not sue that would bounce the tach. If the tach just flucuated a little to match the drop in RPM i'd suspect fuel as well, but it jumps up as well as down.
Thoughts?
- Carb'd 5.0, fuel pressure is perfect
- Mallory Max-Fire dist with Mallory coil
- 2 years old with 4500 miles, never an issue
Mike D
Tampa Fl
07-18-2016, 12:28 PM
60+ views, must have others stumped as well.
I figured the culprit would be the coil, dist, or bad ground.
The issue is Mallory was bought out by MSD, direct replacement parts are not available.
Mike D
Tampa Fl
07-18-2016, 12:50 PM
OH
Cobra Make, Engine: West Coast Cobra, SVO 460, Richmond 4+1
Jumpy tach sounds like an alternator problem (I tried to view earlier and it never opened).
I personally would check the battery and the Alternator, sounds like a voltage issue.
Joey
Liberty Twp, OH
West Coast Cobra
Red W/ White Strips
SVO 460
Richmond 4+1
07-18-2016, 01:00 PM
It sure sounds like you have an intermittant loss of spark problem. That could account for the tach needle fluctuations too. As you said, it could be the coil, distributor cap or your distributor pick-up. I had a a Mallory uni-light many years ago and can remember having to wipe off the distributor's pick-up light every now and then due to ozone deposits. It would cause it to miss if the lens got cloudy.
Too many toys?? never!
07-18-2016, 03:21 PM
I did a quick check at all of the connections and all seemed tight and secure, even turned the lights off in the garage to look for arcing, nothing. The volt meter reads a steady 14 volts at idle with not fluctuation.
Mike D
Tampa Fl
07-18-2016, 03:26 PM
I put an ohm meter on each plug wire, good there. Took the cap off and cleanded each contact as well as i could, no change.
It's strange that at idle the tach jumps all over the place, sometimes as high as 4-4.5k rpm, all while just idling. You can see/feel the misfire at idle as well.
Very strange.
I'm at a point where i'm either going to build a 347 stroker or do a 351 stroker so unfortunaltly i can't replace the distributer until i know what kind of build i'm doing. I need a quick bandaid.
Mike D
Tampa Fl
07-20-2016, 05:01 PM
I changed out the coil with an MSD Blaster SS and went through every ground wire, still having the same issue.
As mentioned earlier, i'm replacing the motor with a 392 so i'd prefer not to throw $250 into a new distributor if i don't have to. But i have 2-3 more races on this motor before i'm ready for the swap.
Would bad plug wires cause the tach to jump?
Any additional thoughts?
Mike D
Tampa Fl
07-20-2016, 05:24 PM
I would disconnect the tachometer, and observe engine behaviour.
A fault tach can cause all of this.
Since it is connected to the coil negative, any internal short to ground is like a random ignition cut off.
07-20-2016, 05:43 PM
I should have mentioned earlier, i did actually try that. No change.
I appreciate the suggestions!
Mike D
Tampa Fl
07-20-2016, 05:57 PM
Ok.
Sounds like it must be the distributor.
What else can make the tach jump that much?
What wires have you got?
I would run spiral wound plug wire, and resistor plugs.
07-21-2016, 03:48 AM
Alternator is a possibility, it happened to me
Basque1
07-21-2016, 04:00 AM
I thought the same, but the volt guage on the dash shows a perfect 14 volts on startup with no fluctuation. Is there another test i could do, i know mine was pretty basic.
Mike D
Tampa Fl
07-21-2016, 08:27 AM
KS
Does your Mallory distributor use an optical module? Mine does and I blew out three of them in rapid succession. There is a device that installs between the coil and the distributor that is said to "clamp" (Mallory's term) voltage spikes...once I installed one things started working again, but it was a lengthy investigation to solve my problem.
Hope you get it fixed!!
Dughy
YD,E./PNB
07-22-2016, 03:28 PM
So I ordered new 9mm Ford Motorsport wires, that wasn't it. I pulled the valve covers, everything looked good. All the plugs looked good, compression was 140-170 on all calendars. Still misfiring and popping as I slowly rev it.
I hate to replace the $553 Mallory distributor if that's not it. Anything else?
Mike D
Tampa Fl
07-23-2016, 04:55 PM
Cobra Make, Engine: SPF#0760
Did you look to see if the center contact on the rotor is making good contact with the cap center electrode?
Also, somewhere there was a thread on distributor phasing....
Ground and power connectors/wires all in good condition.
If you source the ignition key-on power from the ignition switch, perhaps try a jumper and temporarily power it from a good known source. Ignition switch could be on the fritz...
Easy enough to do a resistance test on the wires...
SPFWiringDiagrams@Comcast.net
07-26-2016, 11:40 AM
Did you check the mechanicals on the distributor? Is the drive gear slipping? Are the bearings shot? Is the distributor a tight fit?
Dan in Arizona
CCX3209
07-26-2016, 06:54 PM
I think i have in narrowed down to the distributor. It has a bad rev limit dip switch and the center conductor is a little worn. Swapping in a new motor as we speak so i'm going to stop troubleshooting.
Thanks for the suggestions!
Mike D
Tampa Fl
