Like Tree1Likes
  • 1 Post By twobjshelbys
Old 07-10-2018, 07:19 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Default Garage Floor Jack Recomendations
I know this has been covered before but I can't seen to search for it successfully...... I an looking to replace my rolling floor jack and looking for some recommendations from the CC collective..
Something lighter than my really old steel Sears unit - so probably aluminum.... and something that lowers the car a bit slower if possible, not like a magicians stage trap door opening.
I have seen what Harbor Freight has to offer, while some are nice looking, I have never heard any good reviews (or experience) on most everything they sell... but open-minded.
Jack portability is not requirement but a lighter and smaller footprint can only be a plus in the long run. And no plans to be jacking semi's down the road, so capacity only need to lift the fiberglass car. And I don't lift the car from differential housing so extended reach is not required.
Thanks for any and all suggestions in advance....
Blas
SPFWiringDiagrams@Comcast.net
Old 07-10-2018, 07:55 AM
Danr55's Avatar
Napa sells a small blue floor jack that works well and goes under the car. The handle breaks down and the whole thing will fit in the boot.
Dan in Arizona
CCX3209
Old 07-10-2018, 08:02 AM
HI Cobra's Avatar
I have had 2 small aluminum and one larger aluminum Harbor Freight jacks for
a number of years with no issues. They frequently have sales so you should be able to get the small one for < $75. app 3 1/2" to 17" reach. I always use a
small wood block, if possible, to avoid scratching or possible slippage so I don't have metal on metal.
Flip
Old 07-10-2018, 08:38 AM
I have the small aluminum floor jack and it's ok. I carry a small Honda
scissor jack as recommended by ERA. I got rid of the jack operating rod
and welded a nut to the jack where the rod inserts and now carry a 3/8"
socket extension bar 18" long and a 3/8" ratchet in the trunk. It is a bit
easier to use the little scissor jack and it is dead reliable.
Old 07-10-2018, 12:29 PM
AC Delco 2 Ton Scissor Jack 341111 has a 3/4" drive hex on it.
Just put 3/4" socket with a couple long extensions on ratchet and GTG.
Lift up to 13" with minimal effort
Old 07-10-2018, 01:03 PM
twobjshelbys's Avatar
Get the low profile aluminum jack from Harbor Freight.
HF has a "reputation" for being cheap, and in some things they are, but this jack is excellent. My friend that worked on my Cobra has a shop and got two of them. He also restores cars and uses them alot because they are also light.
Dwight likes this.
CSX4005LA
Old 07-10-2018, 02:03 PM
HF has both ends of the quality spectrum.
I have found their 3 Ton Daytona Super Duty to be excellent.
Copied from the Snap-On FJ300 for 1/3 the cost.
3-3/4" flat to 23-1/8" and a long 50" handle.
Built sturdy and all steel so it's not light (103bls).
Old 07-10-2018, 05:05 PM
joyridin''s Avatar
I have a HF jack I bought 25 years ago and it still works great. I beat the living hell out of it and never added a drop of oil. I bought another one about 5 years ago and it has been great also. My brother and Dad have them with no problems.
HF makes some shady tools, but their jacks seems to work great!
Old 07-10-2018, 07:03 PM
1795's Avatar
Blas,
I have purchased two HF aluminum race jacks. The lighter duty one works fine, but does not have a very high lift. The low profile heavy duty one is great. It is the right height to get under the cobra, is light weight and has a nice lift. No complaints at all about it.
Old 07-10-2018, 07:27 PM
Blas's Avatar
Looks like I will need to revisit the HF jack options.... thanks all.
Old 07-10-2018, 07:48 PM
DanEC's Avatar
I second the aluminum HF jack. I also like their aluminum jack stands. I bought the saddle pads to go with them.
ERA 782 Running
Old 07-10-2018, 10:43 PM
520SC's Avatar
Cobra Make, Engine: 1966 Street Beasts Cobra 427 S/C, 502 cid
https://www.amazon.com/Powerzone-380...ton+floor+jack
I have two of these. They're terrific.
Todd
Old 07-11-2018, 05:14 AM
Cobra Make, Engine: BDR, 418
Default Jacks
I have a twenty + year aluminum 2 1/2 ton from HF that still works great and doesn't leak down. I also just purchased a FAST JACK.
Got the 7,000lb. so I could use it on my truck but it's still small enough to fit under the Cobra and Vette with no issues. I'd recommend this jack/lift to anyone who doesn't have room for a "regular" lift.
Old 07-11-2018, 06:07 AM
RockBit's Avatar
I have thiss jack from HF. Works great.
https://www.harborfreight.com/automo...ump-62516.html
Chris
Old 07-11-2018, 06:11 AM
Sawdust's Avatar
Blas
I have great floor jack from Napa. It's the low profile version. It fits right under the Cobra front and back. Sorry I don't have a part number.
Old 07-11-2018, 09:01 AM
Registered User
The last jack I purchased came from Costco a few years ago. I got the Arcan hybrid 2.5T aluminum/steel HJ2500. Works great for all my vehicles including the SUVS. In my opinion, Costco has a much better return policy than HF should you have any issues.
Old 07-11-2018, 10:12 AM
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
I need a jack with a low front and longest reach for various low profile cars, I chose the Arcan XL 2T. 24" maximum lifting height and dual piston action for controlled lifts.
https://www.floorjackshop.com/the-be...jack-reviewed/
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
