1Likes
Post By twobjshelbys
07-10-2018, 07:19 AM
Cobra Make, Engine: SPF#0760
Garage Floor Jack Recomendations
I know this has been covered before but I can't seen to search for it successfully...... I an looking to replace my rolling floor jack and looking for some recommendations from the CC collective..
Something lighter than my really old steel Sears unit - so probably aluminum.... and something that lowers the car a bit slower if possible, not like a magicians stage trap door opening.
I have seen what Harbor Freight has to offer, while some are nice looking, I have never heard any good reviews (or experience) on most everything they sell... but open-minded.
Jack portability is not requirement but a lighter and smaller footprint can only be a plus in the long run. And no plans to be jacking semi's down the road, so capacity only need to lift the fiberglass car. And I don't lift the car from differential housing so extended reach is not required.
Thanks for any and all suggestions in advance....
Blas
SPFWiringDiagrams@Comcast.net
07-10-2018, 07:55 AM
Napa sells a small blue floor jack that works well and goes under the car. The handle breaks down and the whole thing will fit in the boot.
Dan in Arizona
CCX3209
07-10-2018, 08:02 AM
I have had 2 small aluminum and one larger aluminum Harbor Freight jacks for
a number of years with no issues. They frequently have sales so you should be able to get the small one for < $75. app 3 1/2" to 17" reach. I always use a
small wood block, if possible, to avoid scratching or possible slippage so I don't have metal on metal.
Flip
07-10-2018, 08:38 AM
I have the small aluminum floor jack and it's ok. I carry a small Honda
scissor jack as recommended by ERA. I got rid of the jack operating rod
and welded a nut to the jack where the rod inserts and now carry a 3/8"
socket extension bar 18" long and a 3/8" ratchet in the trunk. It is a bit
easier to use the little scissor jack and it is dead reliable.
07-10-2018, 12:29 PM
AC Delco 2 Ton Scissor Jack 341111 has a 3/4" drive hex on it.
Just put 3/4" socket with a couple long extensions on ratchet and GTG.
Lift up to 13" with minimal effort
07-10-2018, 01:03 PM
NV
Get the low profile aluminum jack from Harbor Freight.
HF has a "reputation" for being cheap, and in some things they are, but this jack is excellent. My friend that worked on my Cobra has a shop and got two of them. He also restores cars and uses them alot because they are also light.
CSX4005LA
07-10-2018, 02:03 PM
HF has both ends of the quality spectrum.
I have found their 3 Ton Daytona Super Duty to be excellent.
Copied from the Snap-On FJ300 for 1/3 the cost.
3-3/4" flat to 23-1/8" and a long 50" handle.
Built sturdy and all steel so it's not light (103bls).
07-10-2018, 05:05 PM
I have a HF jack I bought 25 years ago and it still works great. I beat the living hell out of it and never added a drop of oil. I bought another one about 5 years ago and it has been great also. My brother and Dad have them with no problems.
HF makes some shady tools, but their jacks seems to work great!
07-10-2018, 07:03 PM
Blas,
I have purchased two HF aluminum race jacks. The lighter duty one works fine, but does not have a very high lift. The low profile heavy duty one is great. It is the right height to get under the cobra, is light weight and has a nice lift. No complaints at all about it.
07-10-2018, 07:27 PM
Looks like I will need to revisit the HF jack options.... thanks all.
07-10-2018, 07:48 PM
I second the aluminum HF jack. I also like their aluminum jack stands. I bought the saddle pads to go with them.
07-10-2018, 10:43 PM
HI
Cobra Make, Engine: 1966 Street Beasts Cobra 427 S/C, 502 cid
Todd
07-11-2018, 05:14 AM
Cobra Make, Engine: BDR, 418
Jacks
I have a twenty + year aluminum 2 1/2 ton from HF that still works great and doesn't leak down. I also just purchased a FAST JACK.
Got the 7,000lb. so I could use it on my truck but it's still small enough to fit under the Cobra and Vette with no issues. I'd recommend this jack/lift to anyone who doesn't have room for a "regular" lift.
07-11-2018, 06:07 AM
Chris
07-11-2018, 06:11 AM
Ont
Blas
I have great floor jack from Napa. It's the low profile version. It fits right under the Cobra front and back. Sorry I don't have a part number.
07-11-2018, 09:01 AM
Registered User
The last jack I purchased came from Costco a few years ago. I got the Arcan hybrid 2.5T aluminum/steel HJ2500. Works great for all my vehicles including the SUVS. In my opinion, Costco has a much better return policy than HF should you have any issues.
07-11-2018, 10:12 AM
TN
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
I need a jack with a low front and longest reach for various low profile cars, I chose the Arcan XL 2T. 24" maximum lifting height and dual piston action for controlled lifts.
https://www.floorjackshop.com/the-be...jack-reviewed/
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
