Like Tree1Likes
Old 10-26-2018, 04:54 AM
undy's Avatar
The last 3 or 4 clutch change-outs I've done has been without a "professional" clutch alignment tool. I simply use a 6" or 12" 3/8" socket extension tool and a roll of electrician's tape. I wrap the bitter end of the extension with tape so it fits snugly in the end of the crank and then measure where the splined portion of the clutch disc will be riding on the extension. I then wrap that part of the extension with tape so it fits snugly in the clutch disc. This procedure has never failed me on the first attempt!
Too many toys?? never!
Old 10-26-2018, 07:54 AM
Originally Posted by undy View Post
The last 3 or 4 clutch change-outs I've done... This procedure has never failed me on the first attempt!
I have no doubt about that. I'm just deciding whether I should place a bet on whether funfer2 disregards my advice and eats his thrust bearing for lunch.
Old 10-26-2018, 09:33 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
And you probably need the special spacer that goes between your TKO and the block.
By special spacer between the TKO and block, do you mean the bellhousing?
rodneym
Old 10-26-2018, 09:35 AM
Alright, but it is between the the transmission and the block, just not right up against the block.
Old 10-26-2018, 10:11 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
AC,...are you sure on those specs ?
Was looking on Jegs and did not see them
Dead sure
Old 10-26-2018, 11:38 AM
dcdoug's Avatar
I used this McLeod clutch alignment tool from Summit a few months ago. Snug fit but worked fine. FE, TKO, McLeod clutch
https://www.summitracing.com/parts/MCL-105313-F
I also have the McLeod T/O bearing: https://www.summitracing.com/parts/MCL-16031
www.partskeeper.com
Old 10-26-2018, 11:41 AM
What were you posting on the local club board about having to take your valves apart or something?
Old 10-26-2018, 11:54 AM
dcdoug's Avatar
Was bored.
I finally got the engine back in the car after the rebuild from the failed #5 main bearing (remember that thread?). After cam break-in I had to put the inner springs in and was looking to borrow a valve spring compressor that worked with shaft mounted rockers. I learned that the lever style typically used for stud mounted rockers has a slightly rounded area on top where the lever bends and is designed to work with rocker shafts.
www.partskeeper.com
Old 10-26-2018, 11:59 AM
Yes, I remembered that something had happened... but it was soooooo long ago that I couldn't remember what. I figured your car had just been over at Scott's house for the past year or two again.
dcdoug likes this.
Old 10-26-2018, 12:02 PM
dcdoug's Avatar
I spared him this time.
www.partskeeper.com
Old 11-01-2018, 05:49 PM
FUNFER2's Avatar
Now why,....would I believe anything you say ? Duh....
Kevin
Old 11-01-2018, 06:01 PM
FUNFER2's Avatar
Never used this type with a zerk. Just so it doesn't get over greased, it would be nice.
What size of the bushing/bearing did you use ?
Think I'll try a bearing.
I need to know the bearing size to buy the correct tool.
https://www.summitracing.com/search/...lignment-tools
Kevin
  #33 (permalink)
Old 11-01-2018, 06:37 PM
A "self-aligning" TOB is better for you.
  #34 (permalink)
Old 11-02-2018, 08:08 AM
FUNFER2's Avatar
I've never seen this tool before. It looks trick, so msy hsve to add it to my tool box.
15 bucks @ rockauto.
Product: W1157P
I could not find the throwout bearing on rockauto ?
McLeod Throwout Mechanical Bearing Ford
Part Number: 673-16031
Kevin
