Old 02-23-2004, 06:49 AM
Question Right sidestering to left sidestering
I'm from Denmark and has my heart is set for a used Dax cobra, but the downside is that the steringwheel is in the wrong place.
Is it difficult to change it to a left sidestering wheel?
Like you have in the States.
And do you the cost approx. ?
Old 02-23-2004, 12:55 PM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Hi,
There are a number of things to change.
- change to a mustang steering rack- weld on new brackets
- move the brake pedal and master cylinder over to the other side,new brackets and brake lines
- move the clutch brackets and master cylinder or cable to the other side.
- move the steering wheel and new brackets to the other side.
- move the gauges to the left side also.
Then once it's all done you would probably have to get the car safety inspected.
No big deal ,probably a few grand ,depending on who did the work.
Perry.
Old 02-23-2004, 01:14 PM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Also, the gas pedal linkage would have to shift over to the left side which is doable. You would need a new left side dashboard which, depending upon the wiring harness could be easy or could require a few extension wires to reach the new location of the gauges.
Good Luck.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Old 02-23-2004, 02:28 PM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Orskov - why convert? Plenty of daxes built with LHD for Europe - try 'phoning Dax themselves for details.
Wilf
Old 02-24-2004, 10:44 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
...and for most cars the foot boxes are different side to side (at least they are in an ERA). The "off" side foot box is smaller ie narrower and not as tall (so that the battery can sit on it).
J
