| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
03-02-2004, 03:32 AM
NC
Cobra Make, Engine: Its red (or Blue) with a 427 and completely fictional.
Parts needed to complete FFR
I am looking to buy a FFR Roadster. Do any of you have a complete list of parts needed to complete their kit from their assembly manual? I am going to go with their Pin drive irs, 17 inch wheels, 4 speed toploader, and all aluminum 427 FE. Also,
how accurate is their body to orginal specs? I would like to do a non doner build.
03-02-2004, 04:25 AM
SC
DONOR PARTS FROM A FORD MUSTANG 1987-1993
ENGINE / DRIVETRAIN
CLUTCH CABLE-1
ACCELERATOR CABLE-1
ENGINE, 5.0L FORD & T-5 TRANS, W/BOLTS/NUTS
TRANSMISSION MOUNT W/BOLTS
DRIVESHAFT AND 4 ORIGINAL BOLTS
SPEEDOMETER CABLE
CIRCLIP, CLUTCH CABLE RETAINER
MOTOR MOUNTS, CLEAN STRAIGHT, W/OEM NUTS
MASS AIR SENSOR
OXYGEN SENSORS
EXHAUST HEADERS
FLANGE NUTS, HEADER
RUBBER BUSHING, REAR EXHAUST HANGER
UPPER RADIATOR HOSE
HEATER HOSES, CUT AT FIREWALL, W/OEM CLAMPS
RADIATOR W/CAP
LOWER RADIATOR HOSE
FAN SHROUD W/OVERFLOW TANK MOUNTED
FUEL TANK W/CAP AND MOUNT STRAPS
FUEL FILTER W/BRACKET AND HOSES
HIGH PRESSURE FUEL LINE, TANK TO FILTER
LOW PRESSURE RETURN FUEL LINE TO TANK
HIGH PRESSURE FUEL LINE W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
LOW PRESSURE FUEL LINE W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
FUEL EVAPORATIVE CANISTER, SOLENOID AND TUBING
EMERGENCY INERTIA CUT-OFF SWITCH
BRAKE ASSEMBLY, FRONT, CUT 4" INTO STEEL LINES
MOUNT, REAR BRAKE LINE, RIVETED TO DONOR
MASTER CYLINDER, BOOSTER, DISTRIBUTION BLOCK, STEEL CONNECTION LINES
FRONT WHEELS, 15" ALUMINUM, FAN/TURBINE STYLE W/ 8 LUG NUTS
MOUNT, FRONT, FLEXIBLE HOSE TO STEEL LINE, MOUNTED TO BODY
EMERGENCY BRAKE HANDLE, CABLES, W/HARDWARE
BRAKE ASSEMBLY, REAR, W/LINES ON REAR AXLE
REAR WHEELS, 15" ALUMINUM, FAN/TURBINE STYLE W/ 8 LUG NUTS
REAR QUAD SHOCKS W/ MOUNTS AND OEM NUTS/BOLTS
SPINDLES, FRONT
CONTROL ARMS, REAR UPPER W/BOLTS/NUTS
CONTROL ARMS, REAR LOWER W/BOLTS/NUTS
REAR AXLE ASSEMBLY, COMPLETE
COIL SPRINGS, REAR, W/OEM RUBBER ISOLATOR SEATS
REAR SWAYBAR (OPTIONAL)
A-ARMS, FRONT LOWER W/ BOLTS/NUTS
UPPER STEERING COLUMN, W/IGNITION, TURN SIGNAL STALK, NON-TILT ONLY
STEERING RACK W/TIE RODS, ENDS, BOOTS, NUTS, MOUNT BUSHINGS
STEERING SHAFT ASSEMBLY, W/LOWER U JOINT, OEM NUTS/BOLTS
WIRING HARNESS, ENGINE
HORNS
IGNITION CYLINDER WITH KEY
VACUUM RESERVOIR, CYLINDER SHAPED, BLACK PLASTIC
GROUND STRAP, BATTERY CABLE WITH TERMINAL
WIRING HARNESS, REAR
COIL, STARTER SOLENOID
WIRING HARNESS, DASH
WIRING HARNESS, FRONT
EEC IV COMPUTER W/ PLASTIC HOLDER
WIRING HARNESS, TRANSMISSION
PEDAL BOX, BRAKE CLIP AND (2) PLASTIC WASHERS
GAUGE CLUSTER
ACCELERATOR PEDAL
SHIFTER BOLTS
03-02-2004, 06:37 AM
TX
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
FFR vs CSX BODY Shape
LwCwb,
This has been listed in other previous posts;
A. The most obvious is the "perky butt" issue of the rear area is turned up from the door area at an angle to the road.
B. The roll bar is 2" and at an odd angle with the brace.
C. The hood scoop is wrong shape and molded into the hood, not pop riveted to it like a Competition or S/C COBRA.
Those are the obvious items seen at a distance, the more subtle, the nose is shaped different, stubby/flat like, has bezel base raised areas for the front parking lights..... I'll stop there since the others are not obvious to most.
Do a search function for the COBRA body shape, profile, differences, and such for more detailing ideas.
grumpy
03-02-2004, 12:27 PM
NC
How accurate is the Tristate motorsports body, and will it bolt up to the FFR frame?
03-02-2004, 12:34 PM
NJ
If you are looking for a nice build and an accurate body check out
Antiques & Collectibles in Buffalo.
My build site: http://www.priveye.com/cobra.htm
Nicest thing is that you get the body gelcoated and it comes from the factory looking like a paint job...just a perfect finish. Some have just clearcoated the gelcoat. I am going into my 4th year on the road and haven't painted or clearcoated yet. I saved about 3-6 thousand.
Roscoe
Roscoe
03-03-2004, 06:55 AM
NJ
Cobra Make, Engine: FFR 4481K, 1970 351W
Yes the tristates body bolts to the FFR Frame. It is a direct replacement.
In order to save some dough, I used the ffr body and just purchased the hood (and rivet on hood scoop) and trunk from tristates.
Matt
http://www.mattcuozzo.com/IMG_0328x.jpg
| Thread Tools |
| Display Modes |
Linear Mode
