Like Tree1Likes
  #81 (permalink)
Old 04-17-2009, 01:10 PM
Cobra Make, Engine: SPF 239
RodKnock,
I'm all about air flow. The 58mm throttle bores are only 2.283 inches
the 3.000 are 76.2mm. roughly 25% more area
The engine is an all aluminum 565 ci
Its an A96 block with 351 main journals (2.750 vs. 3.000)
forged Ford/Sonny Bryant 4.250 stroke crank with 2.200 rod journals
6.800 rods
TB coated spherically dished 4.600 JE pistons, 11.8-1 @ "0" deck with a .040 gasket.
Charlie Evans ported SCJB heads 2.25 intakes, Isky springs, Titanium retainers, 400 cfm @.800 lift. TB coated combustion chambers and exhaust ports
Danny Bee belt drive
ATI damper
Ed Pink 5 stage dry sump pump with a oil-air separator
Billet Fab 2 piece pan with piston squirters
Meziere remote 55gpm water pump (reverse flow cooling system)
Roller cam bearings with oil squirters
Blue thunder Competition valve covers with valve spring oilers
The goal it see how much hp I can make on pump gas, naturally aspirated.
To me, detonation control it key. So I'm working to control the combustion process. Keeping the heat out of the head and the piston.
Anyway, with the 3" throttle bores should offer no intake restriction at whatever
Jason
  #82 (permalink)
Old 04-17-2009, 01:17 PM
RodKnock's Avatar
Originally Posted by D-CEL View Post
RodKnock,
6.800 rods
ATI damper
Jason
Holy Mackeral
I just have a puny 482. Next...engine...must...build...bigger...
  #83 (permalink)
Old 04-17-2009, 02:10 PM
In theory, a carb or an EFI system that have equal flow and are properly tuned will make the same power. Flow is flow at WOT (wide open throttle). What we are really talking about is low and mid range power and drive-ability.
The main advantages of an EFI system over a carb, comes from its ability to precisely control the mixture. The result is better drive-ability, enhanced fuel economy and usually a flatter, wider torque curve under the WOT threshold.
But with these "PROS" come with some big "CONS" (no pun intended to the EFI mfgs) primarily system complexity and much higher costs. On top of that, you have to re-learn how to tune. The good part is that tuning becomes more scientific in practice, taking away some of the Juju associated with adjusting a carb.
Conversely, carbs are cheap(er) and simple(er) and for the most part can be made to produce sufficient power and acceptable drive-ability. While cabs work, to me they are a “compromise” system. I run them, but I don’t like them!! LOL
We all search for BIG HP in our mostly STREET DRIVEN toys.
But we must all remember that carbs need Vacuum to function. The wilder the engine combination becomes, the less happy most will be with the street manners of a carburetor.
EFI doesn’t need or care about vacuum and because the fuel is forced into the engine and the high level of control, it can be used to tame an otherwise….grumpy motor, another advantage.
While it is interesting to see head to head comparisons of the power, I think the true measure is how they start and drive on a cold morning in the mountains. How crisply it accelerates after idling for half an hour on the freeway when it’s 110 Deg. How controllable is the power delivery when you’re rolling into the throttle while exiting a hard right hand turn.
All things I don’t like about my very expensive, well tuned, super trick carb.
I’m putting EFI on my new motor, because it has flow potential that no carb can match thereby making the most possible HP and torque and with the right ECM (BIG STUFF or ACCEL DFI) will offer the best possible drive-ability. No compromises.
To me that is worth the additional cost and extra effort.
As I have said many times, there is no right way or wrong way, just opinion.
Jason
Well that's kind of true, from what I have learned. I remember reading an article in Hot Boat years ago, testing Merc's then relatively new 454 packages, One a 454 HO and the other, a 454 EFI. Reportedly, both had the same short block and heads, the differnece being only the induction unit, a holley carb on a dual plane intake, and the other a tuned port, 8 runner FI intake. The testing revealed the Carbed motor out ran, made more power than the EFI version of the same engine, by like 2-3 mph in the same boat, by radar gun. What was explained is that a carburetor can be taylored to optimize fuel droplet size, whreas the EFI system sprays a mist like fuel, which vaporizes more easily, taking the place (space) of would have been additional air (O2) with the carbed engine, enabling the carbed engine to make slightly more power. Interesting.
  #84 (permalink)
Old 04-17-2009, 02:21 PM
Lol, yea I always laugh when I read the "How much HP is enough" posts.
Originally, i was going to build a 598 (4.500x4.600). But Lem & Charlie Evans talked me down. LOL
They said "Boy, that thang will light the tires like a Nitro funny car if you put a long stroke crank in it, you just cant hook that kinda torque"
I asked the guys a 460.com what they thought it would make. The low estimate was 800hp, the high was 950hp.
I want it will make 900-920hp.
It should easily run in the 9's at over 150.... so long as it goes straight......
My goal is to run that Car and Driver 0-200-0 deal. It would be nice to have a Cobra in the competition that actually brought a gun to the gun fight. You need way more than a Roush small block to run with a 1000hp Ford GT.
I think we would put a serious scare into those big turbo guys out to about 150-160mph.
Shoot, Ill even bring a Comp windshield for fun.
Jason
  #85 (permalink)
Old 04-17-2009, 03:08 PM
lovehamr's Avatar
Stolen Avitar
Smile
D-CEL, I still think you need to drop those crappy CJ heads, man-up a little and build one of these:
He he he !!!
Steve
  #86 (permalink)
Old 04-17-2009, 03:37 PM
Steve,
The new BOSS head is sooo sexy! I like them, just not it a Cobra. They need to be out where they can be seen!
I was thinking about using the block that's in my car now building a 604 (just sounds scarier than a 598) bolt a big 14-71 and an EFI buzzard catcher on the dam thing. A chopped, steel bodied, fenderless, hoodless, 33-34 five window coupe would be the perfect home!
Ok im in! wheres your check book!!
Jason
  #87 (permalink)
Old 04-17-2009, 04:24 PM
Anthony,
Kind if true?
To say that the EFI system made less hp because the fuel was “occupying space” that should have been occupied by air… confuses me.
The mixture of air and fuel (a/f ratio) to achieve peak performance is fairly straightforward. Chemically correct is 14.7:1, slightly lower in practice. If the volume of fuel was so great that it displaced air, the a/f would be hugely rich (read to much fuel). Combustion performance would suffer or not work at all.
Are you saying that a carbs make more power because they rely on vacuum and therefore the fuel takes up less space in the combustion chamber?
I think the article was comparing the dual plane manifold and a Holley Carb vs. the early Mercury Cast aluminum EFI manifold with a single throttle body and a small square flame arrestor. It successfully showed that the EFI system made less peak hp than the carb, because the intake tract was long and more restrictive.
Jason
  #88 (permalink)
Old 04-22-2009, 03:35 AM
Yes it is straightforward. The mixture ratio is 14.7:1 by weight/mass, where as the O2 is gaseous, and the gasoline is in a liquid/vapor state. The more the gasoline is in a vapor state, the more volume it takes up, displacing the volume that could have been taken up by additional air (O2). The better you can keep the gasoline in a liquid state, the more "compact" its volume, the more air (O2) you can get into the engine. There is an optimal fuel droplet size for maximizing HP, and different factors affect this, whether the carb has down leg or annular boosters, style of intake, fuel injection, high or low pressure. Everything can be optimized. Were not talking huge values, but values that can be detected.
I think the article was comparing the dual plane manifold and a Holley Carb the early Mercury Cast aluminum EFI manifold with a single throttle body and a small square flame arrestor. It successfully showed that the EFI system made less peak hp than the carb, because the intake tract was long and more restrictive.
I'm saying that with carbs, you can likely better optimize fuel droplet size, optimize the degree of gasoline vapor to maximize HP, where as with EFI, you spray the fuel under high pressure, resulting in more gasoline vapor which I'm sure optimizes combustion, efficiency of combustion, emissions, but may give away a little performance.
The article compared two identical 454 long blocks, except for the intake, induction system. One was I think called a 454 HO, and the other a 454 Magnum. Anyways, one had a carb on a dual plane intake, and the other was a multiport cross-ram like EFI, (like a newer LT1) , with a single throttle body at the front of the intake, and then 8 injectors, one at each port. Interesting article.
  #89 (permalink)
Old 09-25-2009, 06:00 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Some additional thoughts on the EFI vs carb question. In many cases, an EFI setup (when properly tuned) can be bolted onto an engine build for a carb and performance and drivability will improve. This is due to the EFI motor's ability to deliver an broader and more ideal range of fuel and timing in any give range of engine load and RPM (as well as responding better to transient conditions like mashing the throttle at low loads/RPMs). EFI is also very helpful in solving difficult tuning problems like big cams with short individual carbs or throttle bodies.
Something to consider is what happens when a motor is built with EFI in mind in the first place. Carbs need a strong vacumn signal to work. This is especially true at low RPMs and idle (this is why cam selection is critical with webers for example). This forces an engine builder to pick a cam that can provide some level of idle vacumn. EFI systems do not need this and therefore cam selection, intakes, etc. can be tuned for maximum power and torque without these compremise. This coupled with that fact that all restrictions required to create lower pressures to atomise fuel in a carb are eliminated give the EFI system a decided advantage in high performance applications.
- Fred
  #90 (permalink)
Old 09-25-2009, 07:16 AM
Default Carb VS. Injection
We dynoed my engine back to back with a 1050 Dominator and a 1650 cfm Wilson throttle body (with spacer). The manifold was a highly modified Victor Jr. The Dominator made 819@7600 and the EFI made 806 @7600. The theory was that the additional cooling provided by the fuel vaporizing upstream with the carburetor may have been responsible for the improvement. Formula 1 engines (several years ago, I am not sure what they do now) had the injection nozzles above the intake trumpets in the plenum probably for the same reason. The location of the EFI nozzles in the intake track on my manifold were not optimum due to packaging which may also account for the difference. The EFI did have a fatter more consistent torque curve and does not crap out under high G stops and cornering. That is the main reason I went with EFI. It also starts much better because it doesn't flood the engine when you move the throttle like those twin 50cc accelerator pumps do.
- Fred
  #91 (permalink)
Old 09-25-2009, 07:23 AM
fkemmerer's Avatar
Any thoughts on the idea of power gains that a difference cam that was optimized for fuel injection might have allowed?
  #92 (permalink)
Old 09-25-2009, 07:40 AM
Default Cam Choice
The cam was optimized for EFI because that was what I was going to run. We just put a carb. on it to see how the two compared. We tried varying the injection timing in relation to cam timing with different sized injectors too. I think if the nozzles were further up stream in the intake runners it might have helped but packaging would have been an issue. One thing we found was that retarding the ignition above 7000 helped with the EFI. We did not try this with the carb. because the main effort was to get the EFI right. We made so many dyno runs the engine had to be freshened with new rings when we got done.
I was really surprised at the results because several years ago we tried the same experiment on a milder engine and it was 20 hp better with EFI. That engine was in the low 700's @ 6700.
  #93 (permalink)
Old 09-25-2009, 07:52 AM
fkemmerer's Avatar
Interesting, what are your thoughts as to why retarding the ignition above 7000 RPM helped the power output with EFI? How much retard did you use?
  #94 (permalink)
Old 09-25-2009, 08:23 AM
I am not really sure, I think it might be related to cylinder pressure going up with rpm because the intake duration is pretty high (292@.050). Total advance was reduced from 32 to 29.5 degrees, the cylinder heads are very good and compression, 14.7 is pretty high. The earlier engine had Edelbrock heads that were highly modified but that engine peaked at 35 degrees advance because the chambers were still basically an FE. It seems that the more advance you need, the poorer the heads are and the less power you make. NASCAR engines are all in the 20's and as you know, very efficient.
As to EFI, I am not sure that it would not have worked with the carb. too, we were out of time and just thrashing the EFI at that point so we did not check it.
  #95 (permalink)
Old 09-25-2009, 01:02 PM
TButtrick's Avatar
Doesn't your EFI ECM lengthen the injector pulse width to give the motor the same fuel shot on startup? A carbed car that doesn't start just as quick or "easily" as EFI has the carb setup incorrectly.
  #96 (permalink)
Old 09-25-2009, 01:53 PM
Default Starting
The carb starts fine when it is cold however when the engine is hot it will not start if you look at the throttle, any movement of throttle linkage dumps enough raw fuel to make for a very slow and rich start, it is a single plane manifold so the fuel runs right down the ports.
The EFI has a temperature curve that you can adjust for starting. You can adjust starting injector pulse width down as temperature goes up and can even adjust the rpm that determines when the engine is running and adjust the pulse width at that point too. I have an MSD with Blaster coil so the ignition is up to it if the plugs aren't soaked. This is not a street carb and has no choke plate so it is not a direct comparison to a street carb.
  #97 (permalink)
Old 09-25-2009, 07:43 PM
TButtrick's Avatar
My experience is the opposite. On a cold first start of the day, I give a half squeeze of the throttle and no choke. Starts first crank. Subsequent warm starts throughout the day, I don't touch the throttle and starts first crank.
  #98 (permalink)
Old 09-26-2009, 05:48 AM
fkemmerer's Avatar
Sounds like you are acting as the "computer brain" to make the carb "smart" .
Seriously, this is one of the fundamental advantages of EFI - the computer does a much more precise job of fuel and timing delivery in a broader range of conditions that our engines operate in. This is especially important on the street where a motor must operate over a much broader range of temperatures, loads, transient conditions, etc. than a race car would encounter.
- Fred
