Old 07-23-2007, 08:56 PM
Cobra Make, Engine: '02 Civic EX Coupe & '95 supercharged SHO
Send a message via AIM to yamahaSHO
Default -10 AN or -12 AN for oil cooler?
Howdy, me again.... I started a post about my supercharged Taurus SHO here.
I am currently trying to setup my oil cooler setup and I am having a really hard time deciding between -10 or -12 AN. Can anyone offer some advice in that area?
I also found out today that my Fluidyne Therm-HX cooler is a tad large for fitment, so I need to sell that off and order a different cooler. I am looking at Earl's Temp-A-Cure coolers and Mocal coolers. Anyone have any experience with the two. Both seem very similar in build and design. My oil can get rather warm, so I'm looking for something that is relatively large and doesn't cause a huge pressure drop.
THANKS!
Old 07-23-2007, 09:03 PM
Power Surge's Avatar
Jason, I think you will be fine with -10 on the SHO. Many Cobra guys run -10 on their cars. Of course, -12 will flow more oil, but I doubt you'll have that kind of flow need over the -10.
Sal Mennella
Old 07-23-2007, 09:23 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Go -10 with the lines. Look at good smooth bore XRP lines Nomex covering. Mocal and Earl both make good coolers and have run both.
Morgan LeBlanc
Fresno CA
Old 07-24-2007, 09:48 AM
So it seems like the consensus is -10 AN. You guys don't think I'll see improvement or added safety with -12 AN? I spin the motor about 1,000 RPM faster than factory and IIRC, the pump is a high flow unit. The biggest part is that I am limited on space. If I have to go with -10 AN for space requirements, I want to make sure I'll be good for even track use.
BTW, I won't be able to use my nice Fluidyne oil cooler as it won't fit without some modification to my bumper. I'm trying to sell it, so if anyone is interested... http://theoildrop.server101.com/foru...e=0#Post943843
Thanks for the help Sal and Morgan!
Old 07-24-2007, 10:19 AM
Old 07-24-2007, 12:04 PM
What I'll do today is order a -10AN and -12AN 90 degree fittings and see what will fit. I may just not be able to fit -12AN.
Thanks!
Old 07-24-2007, 12:07 PM
Jason, -12 is quite larger than -10 in relation to fitting and line size. With what you are trying to do under the hood of your SHO, I would definitely use the -10.
I just snapped a pic of a -10 fitting ontop of my -12 fitting on my Cobra. Hopefully this helps...
Sal Mennella
Old 07-24-2007, 01:57 PM
Sal, thanks for the picture, that helps me visualize. I'll just stick with -10AN.
Old 07-24-2007, 08:04 PM
Sal, do you think this cooler is enough? http://store.summitracing.com/partde...5&autoview=sku
I'll mount it in front of the condenser and the car is anywhere between 550 -600hp.
I'm trying to keep it clean without having fitment problems with the lines, but I'd rather over-cool since I have a t-stat.
Old 07-24-2007, 08:17 PM
I'd say that's roughly the size of a Cobra oil cooler, and I can attest that mine works well.
Another option... get a cooler with a fan (or pair of small fans) mounted to it, and stick it in the fender. This way you're not eating up grille space if it's tight.
Sal Mennella
Old 07-24-2007, 08:33 PM
Hmmm... I don't have fender space.... There's a water injection pump on one side and a HUGE intake on the other. I also have brake cooling ducts taking up some room. I like the idea, so I'm going to look in the garage to see what room I do have.
Old 07-24-2007, 09:36 PM
I just took a look, I don't have any room at all. The pump takes up too much space on the drivers side and the CAI barely fits on the passenger side.
Here's what I'm working with for some of the fittings. The plug on the block is the same plug Pat is using on the race car, however, he is limited to -8AN. I bought an NPT plug that uses and Allen Wrench to tighten down so it sits flush. I'm hoping the -10AN will fit nicely.
BTW, can you post a pic of your oil cooler installed?
Old 07-24-2007, 10:01 PM
RedCSX1's Avatar
Default A few point
Sal and SHO,
The 90 degree corners are not good, actually restrict oil pressure. I run XRP HS-79 lines that have a extremely low pressure drop that have a larger inner bore than most lines that are -10 with all fittings that have a smooth bends.
I have no pressure drop as Rob reported.
http://www.xrp.com/XRPCatalog.pdf
Morgan LeBlanc
Fresno CA
Old 07-25-2007, 05:07 AM
Morgan, I plan to use swivel fittings that have smooth mandrel transitions. I'll look into that hose you suggested.
Thanks,
Old 07-25-2007, 07:19 AM
Morgan, you know my car is built to orginal specs, hence the exact correct oil cooler fittings on my car. Naturally if I were building a car for performance, I'd use a radius tube end 90*.
Sal Mennella
Old 07-25-2007, 08:32 AM
Don DePontee's Avatar
Cobra Make, Engine: FFR-4000 under construction
Send a message via AIM to Don DePontee
Don't forget to run an oil theromstat and yes it's a must have item in any oil cooling system!
Don
Old 07-25-2007, 08:41 AM
Banned
Don
Couldn't agree more. Faster oil warm-up and that's very important on those cold mornings/days. Most oil coolers by themselves are actually TOO EFFICIENT on these cars, especially on the street. If seriously tracking the car, the extra flow from the -12 will be a benefit toward keeping oil temps down.
-Dean
Old 07-25-2007, 09:55 AM
Way ahead of you
http://clubcobra.com/forums/showpost...51&postcount=9
It's a Mocal unit.
Old 07-27-2007, 11:01 AM
Nevermind on the cooler... I found a way to make this large sucker fit. I'm glad as I already have it and it's supposed to be a good unit. I'll post pics when everything is done.
I bought the Mocal SP1T and I'm waiting on the SP1T-HF version to show up too. I think the HF version will make an easier fit with the ports spread out wider. We'll see next week.
Old 07-29-2007, 11:05 PM
Hey Sal, I got the cooler mounted and I'll know tomorrow how well fittings will go in when I get them along with the new sandwich.
Here are some pics...
