Old 06-24-2008, 02:12 PM
Default 427SB Gauges: Running information
A newbie question: I have a 427SB that i have just got running. it seems that everything is reading correctly except the oil temp. it doesn't move unless i push it and then let it sit. initially i thought it was not working. The others read:
Oil press: 40 C
Water: 85 C
Any suggestions?
Old 06-24-2008, 02:15 PM
computerworks's Avatar
...do you have an oil cooler?
Old 06-24-2008, 02:16 PM
Banned
Originally Posted by StreetSnake View Post
Oil press: 40 C
You mean PSI at hot idle?
-Dean
Old 06-24-2008, 02:59 PM
Yes I have an oil cooler. And yes PSI for oil pressure. Sorry
Old 06-24-2008, 03:25 PM
Probably nothing wrong. Block off the air flow through the oil cooler and see what happens. If the temperature still doesn't budge, test your gauge.
Old 06-24-2008, 03:41 PM
my concern is that i've read it is necessary to have the oil temp high enough to boil off any water in the lines. Should i not be worried. thanks
Old 06-24-2008, 05:33 PM
52chevyred's Avatar
Cobra Make, Engine: Street Beasts 302 HO
Streetsnake: You said C for the oil pressure and water temp: are your gauges reading in Celsius? That's 105 degrees on the oil and 185 degrees on the water, if my swamp math is correct.
52chevyred
Old 06-24-2008, 07:11 PM
Oil temp: 60 (hasn't moved) it doesn't move unless I drive it hard and then sit idleing
Water temp: 85 C
Oil pressure: 40 psi (warmed up
Yes my gauges are in celsius Thanks
Old 06-24-2008, 07:21 PM
Water temp: 85 C
My water and oil temp readings track each other thru the temp range, which seems to make sense since they are both fuilds flowing thru the same engine.
Probably try replacing the guage or sending unit.
Old 06-24-2008, 07:53 PM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Street:
It's a good idea to have your oil temp close to the 200 range to outgas contaminants. Try running an oil cooler thermostat if you're concerned that the temp is too low. There are several available that take a minimum of plumbing modifications. You should be able to find them at either Jeg's or Summit just for starters.
DonC
Old 06-25-2008, 06:30 AM
Thanks for all the help
Display Modes
