December 2025
  #21 (permalink)
Old 11-01-2008, 10:09 AM
Rick Parker's Avatar
They are more sensative to the atmospheric and barometric conditions.
The TAD and Nitro Funny Cars run on the edge of hydraulic lock from what I've read (?). And only spin about 900 RPM's for the 1/4 mile.
Rick
  #22 (permalink)
Old 11-01-2008, 10:49 AM
Silverback51's Avatar
If I remember right they have rev limiters set a 8000 RPM's. Using the second round times from Las Vegas last night of 3.781 for TF and 4.062 for FC (Go John Force), that equates to 504 revolutions for TF and 542 for FC.
Of course that does not take into account any wheel spin.
  #23 (permalink)
Old 11-01-2008, 12:09 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
Maybe a dumb question, but can you count on a rev limiter with that much mass?
E
  #24 (permalink)
Old 11-01-2008, 01:30 PM
CHANMADD's Avatar
How do you make an 815 CI engine ?
Throw a lot of money at a lot of parts!!!
John
  #25 (permalink)
Old 11-01-2008, 02:23 PM
ffindling's Avatar
Cobra Make, Engine: Findling 001 - starting scratch build
Unhappy Big motors....
Both the NHRA and IHRA limit bore spacing on these engines to 5" or less.
This places a limit on bore size so the large displacement has to be accomplished by using very long stroke cranks in a raised deck block.
The result being that these monster motors are very undersquare. Since
longevity is not a factor in building drag race motors, these motors can be
made to work. It would be rather difficult to build a streetable motor in
this configuration that would last a reasonable amount of time before a rebuild was
necessary. Since the bore size limitation also restricts valve size as well,
you have to put as much camshaft timing into them as is possible to make
them aspirate well. Building such an engine with a milder streetable camshaft
would probably make the additional displacement fairly useless.
....Fred
  #26 (permalink)
Old 11-01-2008, 03:01 PM
Cobra Make, Engine: Sage Brush Roadsters body, Custom Chassis, SRT-4 Engine
Alot easier for a street applicaton to just use a turbo or supercharger.
If I can push 650whp out of a 2.4L (148ci) and still have a useable powerband, and be reasonably reliable, then imagine how much power could be had from a much larger V-8.
Actually don't imagine it, see it (347ci LS1-based engine w/ a T76 Turbo at "medium" boost in a ~3300lb car):
Inside view: http://gonicd.com/videos/9_47_inside.wmv
Outside view: http://videos.streetfire.net/video/N...7-c7ef813f005d
  #27 (permalink)
Old 11-02-2008, 04:15 AM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Default BIG motors
Contact these people : http://candcmotorsports.com/
Carroll Carter has been building BIG Ford's for many years.
Display Modes
