| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
03-14-2004, 10:05 AM
Transmission cooler?
I would appreciate any feedback on transmission cooling, as I intend on running a Jerico, Jerico recommend for road racing to run a trans cooler, now as I am doing only 5 lap short courses or 20-25 miles of hard use, it may not be that much of a problem!
Another bonus of running a cooler though is fitting a proper filter in, alternatively I could just change the oil periodically and a magnet bung should handle the metal. The downside to the oil cooler system is potential leaks!
A J. Newton
The 1960's rocked!
03-18-2004, 11:26 AM
I run a jerrico with no cooler. I run the same 20 minute sessions. I think in a heavier vehicle for a longer period of time with a driver pushing the car, a cooler would be the smart way to go. Scott
03-18-2004, 05:28 PM
Cooler
Scott,
I will fit one in the system with maybe a Tilton electric pump, Jerico filter and a reasonable 7 row cooler, or maybe a good transmission cooler if they come with the right AN fittings!
Thanks.
A J. Newton
The 1960's rocked!
03-25-2004, 06:49 AM
IL
Cobra Make, Engine: Kirkham #259
Ant
Not sure if this is what you are looking for.... but it's a good idea since there's not many places to get air flow under a Cobra...
http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361
The Fan and cooler don't look to be very thick.... so would fit nicely in between the frame rails....
Just some thoughts..
Morris
Morris
03-25-2004, 12:28 PM
Cooler
Morris,
Appreciate that, and food for thought!
I dont think I need that, as with only doing 10 minute racing here, a lot of guys run nothing, but the question can be asked "how hot is the trans oil, if you haven't got a temp gauge!
A J. Newton
The 1960's rocked!
07-12-2004, 03:56 PM
Ant:
The jerico has oil cooler fittings for the cars doing enduros. If you are only doing 20-30 mile races, don't worry about it. If you want to know the temps, get an inexpensive infra-red gun, and take readings after each session.
If you fit a filter, make sure it has a large enough cross-section so that it does not plug, example - Oberg makes a gearbox filter...
07-18-2004, 04:07 PM
Oil cooler
Gumball928
That makes sense, my old boss has a heat gun, regarding the oil cooler what I was also intending on having was mainly oil filtration to pick up debris mainly, and plumb in an oil cooler as well, but its all additional cost probably!
A J. Newton
The 1960's rocked!
| Thread Tools |
| Display Modes |
Linear Mode
