Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 12-24-2009, 08:19 AM
Default Rear end assembly
Hello,
I have a week off of work and I think I finally have everything to start putting the rear together. I had a couple of questions before i get started though.
1. How do you press in the ten bolts for the housing? Is there a special tool?
2. Is there a measurement that i need to know when I get the bearings pressed onto the axles, such as how far the bearing needs to be from the back of the flange. I'm using drum brakes.
3. Where should I drill and tap for the vent? Anywhere on top of the housing in particular it should be?
Any other tips you can think of would be appreciated.
Thanks in advance and Happy Holidays
Rate This Thread:
