Old 07-28-2015, 03:14 AM
Default Suddenly after 8 years a strange electrical issue
Hi Everyone, looking for some help in finding an issue with my driver side tail lights. Driving home on Sunday, someone flagged me saying that my driver side brake lights were out. I figured it was a bulb. Under closer examination, the lights were actually very faint. Right sidelights were good. I checked the turn signal for that side and not only does it flash (weak light) but doesn't the license light also flash. Right side turn signal works fine.
I've never had an electrical problem. This is a first. Could it be as simple as a faulty flasher under the dash? Why would the license plate light also flash suddenly?
any help would be greatly appreciated.
thank you
Nelson
Old 07-28-2015, 03:30 AM
Tommy's Avatar
I'm not sure I fully understood your description, but if one bulb is weak and another that shouldn't be lit is also on, I suspect you have a bad ground. Run a temporary ground wire from a known good ground to the faulty fixture. If that fixes the problem, you have confirmed a bad ground. Then you need to find/fix/bypass the bad ground.
Tommy
Previously owned EM Cobra
Old 07-28-2015, 05:44 AM
Im running a lucas rear tailights setup including the old connection system. The lights are dim. When i turn the signal light on the driverside, the license light also flashes. When i turn on the passenger side signal light, that works fine and the license plate light doesn't flash.
Old 07-28-2015, 06:12 AM
MOTORHEAD's Avatar
The tailite is getting a poor ground through the license lite would be my first guess. Do what Tommy suggests.
"When Injustice becomes Law,
Old 07-28-2015, 06:29 AM
Sorry in advance about this question since it might be considered as a dumb question. A good ground is found on the frame only since the rest of the car is fiberglass?
Old 07-28-2015, 06:37 AM
Tommy's Avatar
That is correct. To be doubly certain, run a jumper wire from the negative battery terminal as your known good ground.
Second thought: I'm not familiar with your particular light fixture. All fixtures on fiberglass bodied cars have to be grounded, usually with a wire. Sometimes the wire will attach to the body of the fixture if it is metal. Other times it will be one of the wires that goes to the socket for the light. On standard wiring, the ground wire will be black.
Tommy
Old 07-28-2015, 07:13 AM
Thank you, Tonight after work, i will attach a direct line from the socket to the negative side of the battery since the battery is right there. The negative side is already mounted to the rear bumperette frame mounting.
Old 08-04-2015, 04:16 AM
Hey Everyone, Well the issue turned out to be a bad ground wire that had become loose. Tore it all apart, soldered it together with some shrink tube. Good as new. Thankyou for all of your help!!!
Old 08-04-2015, 06:37 AM
Tommy's Avatar
Thumbs up
Glad it was an easy fix.
Tommy
Old 08-04-2015, 11:36 AM
Default A&C lights
Automan, I have extra light sockets from A &C if you need a extra
Jon
