Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 07-27-2018, 01:13 PM
Cobra Make, Engine: A&C 427 s/o
Default engine mount question
hi,
I have a question about mounting my engine in the frame. I have an A&C cobra kit car. The engine I am using is a cast block 427 side oiler. I'm using the motor mounts that came with the kit but there is about a 1 inch difference in space between the motor mounts and the frame. The frame is about 1 inch wider compared to the engine with the motor mounts. Not sure if anyone else ran into this problem before or what they did to fix it. The mounts I'm using on the engine are a 3 hole plate with a rubber block with a threaded bolt in the center. They said there for a ford 427 side oiler, but I did have to wobble out one hole for the oil passage.
Old 07-29-2018, 05:44 PM
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
Originally Posted by cobrabritt83 View Post
hi,
Have you called Joe to ask him if he has seen other customers find similar issues?
I'm not running an FE, but ran into a similar issue when mounting my Coyote. The Coyote's engine mounts were about an inch too narrow to meet the frame/motor mounts supplied by A&C. I ended up spacing the Coyote's mounts out a bit and it seems to fit really nicely now.
Old 07-31-2018, 07:24 PM
FWB's Avatar
FWB FWB is offline
hi,
the plate sounds right but the rubber mount your describing sounds like a full size ford mount, i think you want a mustang mount, try Crites restoration, the mustang mount has two ears on each side for a cross bolt
without pictures its hard to tell what you have or need
Fred B
Old 08-01-2018, 01:27 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
I ended up putting spacer plates behind the motor mounts, between the mount and the frame. If I recall they were different thicknesses
OhioCobraClub.com
Old 08-01-2018, 03:48 PM
Cobra Make, Engine: Contemporary Cobra
Correct motor mounts for a FE are 2270 & 2271 1971 LTD w/390
Jon
The Impossible Only Takes A Little Longer
