Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-03-2009, 11:13 AM
Cobra Make, Engine: Contemporary Cobra
Default corvette pedal box
does the corvette box from A&C come with a brake lite switch? if not what did you use?
Jon
Old 05-03-2009, 05:51 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jon;
Not sure what you mean by "Corvette" box from A & C.
In the pedal box that Pete Clark (Fast Times Rods) made for me he put a Corvette Master cylinder on it for me.
If you get the Ron Francis or American Auto Wire Wiring harness it comes with a brake switch you plum in the brake line coming out of the master cylinder. Very easy, very clean. If you are thinking of a switch that the foot brake pedal comes in contact with when depressed. Can't help you, sounds too complicated.
JIm
OhioCobraClub.com
Old 05-03-2009, 08:39 PM
Cobra Make, Engine: Antique&Collectible 392 stroked
Jon, yes the corvette pedal box from A&C does come with the brake light switch that is activated by the brake pedal arm
pops67
Old 05-05-2009, 12:55 AM
I used a brake pressure switch. This one
http://www.speedwaymotors.com/Pressu...itch,1971.html
Very easy to use. Little brake pressure closes the switch. I ran it on the front brake line. Get the brass tee to hook it up.
Old 05-05-2009, 07:30 AM
1985 CCX's Avatar
I used an inline pressure switch, really cool. If my memory is correct it was purchased through Pegasus?
Old 07-21-2009, 05:43 PM
Default it leaks
i bought the in line brake switch and installed it....it leaks! What can I use to seal the threads?
Jon
Old 07-21-2009, 07:58 PM
Yellow thread sealer from Lowes. It says gas and oil resistant. Comes in a tube. Let it dry before using it.
Old 07-21-2009, 09:29 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Most hydraulic brake light switches are made with an NPT flare and should not leak when torqued correctly. If it is in tight, I would say make sure that whatever you used to 't' the line has the proper female flare first. You may have a mismatch of some sort!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
