Old 01-05-2010, 04:47 PM
Karl Bebout's Avatar
Dan Rat, most any feed and grain place has a certified scale and will give you an accurate weight for just a few dollars.
Karlos
Old 01-05-2010, 06:38 PM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
Originally Posted by fastd View Post
DWRAT.
Now you got me curious; what does your car weight and what kind of power does it put out?
I have a ERA FIA; I am guessing it weighs around 2,600 lbs with gas in it...I would like to get it weighed some day when the opportunity presents itself.
Me thinks you need to get it weighed. I got mine done and it weighs 2160. Take it out and get it weighed.
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 01-05-2010, 07:05 PM
vettestr's Avatar
The scale part is easy and cheap. Dan, we have a rock and stone retailer just N. of Deer Valley and about 21st or 22 Ave. They have a scale used to determine the weight of flag stone or whatever and a before/after check of the vehicle tells them what you loaded.
Every time I have taken a car there they are happy to trade a look at the car for a quick trip over the scale. If you don't need a printout have a pen and paper ready to record the readings. The scale display is on the side of the building and the numbers are about 24 inches tall. If they are not busy they let me roll the front axle on for a reading, then stop in the center of the scale for a gross weight and a quick rear axle weight as I pull the car to the end of the scale.
This method is not as precise as doing all 4 corners independently but works for me.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 01-05-2010, 08:33 PM
John-Tucson's Avatar
DWRAT, we will probably do our yearly "Weigh-In" next month. We use four scales and can give you the total, and the front to rear. Only a couple of the Phoenix guys have come down here for it, you might ask Karl what he thinks of the job that we do.
Old 01-06-2010, 04:10 AM
If you use helium in your tires it will weigh less.
Old 01-06-2010, 04:46 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Congrats Dan.
I get a number of ricers or kids of execs ( living in Detroit means their cars are not -- stock ).
Most of the time I like the, "I don't need to, I look better than you." comment.
Congrats!
Old 01-06-2010, 05:00 AM
Sweet! I always enjoy hearing this stuff. Got my heart pumpin'.
It has been so nasty here weatherwise. I am going into Cobra Driving Withdrawl!!!
Thanks for cheering me up!
JB
Old 01-06-2010, 08:58 AM
vettestr's Avatar
The run up to see the Tucson guys will nail down your car weight for sure. I am guessing the MK2 FFR comes in close to about 2400 pounds max. That is with a driver and as you drove it to the scales. John am I close or can you help with a more educated estimate? Until we hear different lets use the round numbers of 2400 LBS.... maybe a bit high?
The web is full of huge HP claims but a quick scan showed me engines with your goodies averaged from 350 to 450 HP. Found one guy claiming 535HP but had very worked heads and more goodies. I know it is all just chatter until you get the pulls on paper but ballpark numbers at least. If she weighs 2400 LBS and use 350 Hp minus 15% drive train loss then you get 297.5 rear wheel HP so 8.06 pounds per horse and @ 450 hp - 15% = 382.5 and 6.274 LBS per horse. 8 .06 or 6.27 pounds per horse is pretty respectable.
A Shelby GT500KR with advertised 540 Hp minus the same 15% = 459 HP and at 3900 pounds tips the HP per pound to 8.49 LBS per pound. The Shelby is supercharged and uses advertised HP but bet it is a real number. Just bench racing but the numbers are a hoot to compare. The old days you were lucky to get over 1 horse per cubic inch to the wheels and that is in a tank with a zillion pounds.
Jeff Classic
Old 01-06-2010, 10:39 AM
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
I am curious if anyone knows the weight of the CSX cars Loaded and unloaded?
Old 01-06-2010, 10:57 AM
greg schroeder's Avatar
Street racing is illeagal, foolish and should never occur. It's fun too.
I'm all in for a day at Speedworld for a Cobra day. They have club test and tune days when they are lax on tech inspection.
off idle drag pass, DA 750ft.
Old 01-06-2010, 11:05 AM
Danr55's Avatar
Greg, I thought you sold your car. Do you still have it?
Dan in Arizona
CCX3209
Old 01-06-2010, 12:12 PM
My Brother in law has it. He's itching to make a few passes in the car.
  #33 (permalink)
Old 01-06-2010, 12:23 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
and not when it is 105'. Speedworld for the whole club; just taken it easy and all......Street tires only? No "Cheting"...
Fitz
fitzus1@gmail.com
  #34 (permalink)
Old 01-06-2010, 12:44 PM
mikiec's Avatar
Greg,
Can you arrainge a date in late March early April. exclude April10th, for a group day? I would not even mind being the slowest of the day. I'm a 60 second driver.
  #35 (permalink)
Old 01-06-2010, 12:45 PM
Fitz, Jeff's the only one that would cheat. That's why he got thrown off the track the last time we were there with him. Cheater, cheater, cheater!
Karlos
  #36 (permalink)
Old 01-06-2010, 02:49 PM
ItBites's Avatar
I'm in for a couple passes at Speedworld. I couldn't quite get an 11 sec pass with the little-bitty 427, but I think the new 540 may do better...
E. Wood
ItBites
  #37 (permalink)
Old 01-06-2010, 03:03 PM
mikiec's Avatar
I wonder if Karl will have his finished by then?
  #38 (permalink)
Old 01-06-2010, 03:14 PM
Danr55's Avatar
"I wonder if Karl will have his finished by then?" What year are you talking, Mikie?
Dan in Arizona
CCX3209
  #39 (permalink)
Old 01-06-2010, 05:57 PM
Cobra Make, Engine: Contemporary / FE
My better judgement tells me not to comment on this thread. But better judgment be damned I cannot sit back and say nothing. To read that fellow car enthusiasts are racing on the street, bragging about it and others condoning it astounds me.
Street racing, whatever way it is done, is just plain wrong. If you want to contribute to the demise of our hobby, help regulate it out of existance, provide Insurance companies with more reasons to jack up our rates or not insure us at all, and turn the public against us. Just keep it up, your succeeding.
Street racing doesn't make you cool, mean you have a faster car, or impress the people that around you that are driving safely and within the law. God knows we have enough trouble with the police just trying to keep these cars on the streets.
If you want to see how your car compares to other performance cars then do it on a track. That's what tracks are for.
I am sure many will have responses to this stating many factors against my opinoin regarding this issue. So be it. Street racing is wrong .... period.
PS Brent if you wish to remove me from this website because of my position and statements here. I will respect your decision and wish you the very best. But I will not change my stand on this issue.
  #40 (permalink)
Old 01-06-2010, 06:16 PM
DWRAT's Avatar
Concobra,
You have a right to your opinion and I expected it from a few readers just as yourself.
You enjoy your Cobra your way and I will enjoy my Cobra my way.
Dan
PS, hopefully no one will remove you for your opinion.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
