February 2026
Old 12-17-2011, 11:14 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by mikiec View Post
Tinny's cobra was cristened by the rain tonight.
The car looks and sounds good. 367 miles on the odo today.
And, so where is Tinney?
Is it possible the computer he is using was built by Roush?
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 12-18-2011, 12:31 AM
tin-man's Avatar
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Ralph
well, you will not believe this, chit truly happens, not only did it rain on my new baby but on my way back from the Safeway gathering the Beast from Roushverks developed a bad banging noise under the drivers seat whenever I put on the brakes, sorta like I ran over a rock and it hit the undercarriage, plus the vacumm pump for the breaks runs continuously. I will put it on the hoist in the morning to see what has come loose. I guess this is par for the course, huh, and all these little gremlins get to kick you in the ass.
Is this a right of passage for owning a Cobra?
Other than that the car was running like a dream, err, up to that point.
tin-man
Be well, drive fast, live long
Old 12-18-2011, 04:56 AM
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
NOW you are officially welcomed in to the cobra club. We ave all felt your pain. Hopefully something minor but yes, a way of life for a cobra, particurlary those that are blessed/cursed to have a Roush motor although that doesn't sound like anything with motor itself. Good Luck and Godspeed getting it back out on the road.
csx4910
Old 12-18-2011, 08:03 AM
Check you ebrake cables going to each wheel, you may need to tie wrap them so they dont hit anything. Something by your seat? check your transmount and make sure it is tight. Kooky if U ask me. Join SCOF.
Old 12-18-2011, 08:51 AM
Danr55's Avatar
Sounds likes loose sidepipe mount.
Dan in Arizona
CCX3209
Old 12-18-2011, 09:47 AM
More like the blifinator if you ask me.
_____________________
Old 12-18-2011, 09:56 AM
Yes, it is. But, in my experience, if you were able to make it home under your power then it's nothing serious. Pop it up in the air, crawl under it, and take your time looking at things. Fixing your Cobra is part of the joy of owning a Cobra.
Old 12-18-2011, 12:33 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Over maintenance and worrying is the way to always operate. I always provide overkill to my car. It saves headaches. Gordon, (Levy Racing), Bob Reams, (Old B&R Automotive), Marty Ceruttis (Napa Autocare) always tell me I do not have to buy new batteries, change the oil, change the brake pads, change the hoses, buy new tires, do a nut and bolt check etc. I just do it because I feel like I should.
Don't want to have to buy a battery outside Selligiman when I would rather be drinking wine! whoops!!
Fitz
fitzus1@gmail.com
Old 12-18-2011, 01:47 PM
Karl Bebout's Avatar
Fitz, I don't blame you for being extremly cautious after the nasty experience you had with your big Levy motor and that crazy clutch you dealt with a few years ago. Pink is still picking chunks of volcanic rock out of his knee after trying to push your car out of his cabin's drive way.
Karlos
Old 12-18-2011, 02:06 PM
Or it may be a defective differential girdle spring in the turbo encabulator.
A classic.
-Sandy
Old 12-18-2011, 05:53 PM
Danr55's Avatar
Car Nut I thought Rousch quit using blifinators. They are so hard to keep tuned.
Dan in Arizona
CCX3209
Old 12-18-2011, 06:05 PM
A classic.
Only if he using the older beehive style.
  #33 (permalink)
Old 12-18-2011, 08:16 PM
Spoooky's Avatar
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
Tin-man, This happened to me and you said it was when you put on the brakes. You could feel a pop at the seat. There were a series of Superformance car #'s that didn't have lock tight or the front calipers nuts and bolts. You car # is right there like mine. Check those caliper nuts and bolts first. I had one sheer right off and lucky it was a a low speed not to do any damage. Contact Lance he knows the car #'s effected. It's worth a look for some piece on mind at least.
  #34 (permalink)
Old 12-18-2011, 08:36 PM
Originally Posted by Spoooky View Post
There were a series of Superformance car #'s that didn't have lock tight or the front calipers nuts and bolts. ... Contact Lance he knows the car #'s effected.
If true that's really going to piss ol' Tinny off, considering they've had his car for the last six months.
  #35 (permalink)
Old 12-18-2011, 10:04 PM
Just a guess, but it sounds like 1) a plumbing problem with that vacuum booster, and 2) that booster may not be secured properly. I have the same unit, and have had the same problems. Once it's plumbed correctly, and secured (check it twice a year) it will be fine.
just my .02
  #36 (permalink)
Old 12-19-2011, 05:27 AM
Danr55's Avatar
Locktite? For that kind of money I would expect lock washers and or lock nuts. I would be really pissed if they relied soley on locktite!
Dan in Arizona
CCX3209
  #37 (permalink)
Old 12-19-2011, 06:54 AM
mikiec's Avatar
Tinny... You want to trade? At 60,000 miles mine should be broken in by now. LOL
  #38 (permalink)
Old 12-19-2011, 08:05 AM
... Check those caliper nuts and bolts first. I had one sheer right off and lucky it was a a low speed not to do any damage. Contact Lance he knows the car #'s effected. It's worth a look for some piece on mind at least.
The affected car numbers were 2600 to 2975. A service bulletin was issued in the summer of '09. Mine is #2708, pulled the wheels and checked, two bolts (one on each front caliper) took a half turn to tighten, whew glad I checked. I removed the bolts, cleaned and used red Locktite and tightened to spec. Checked a month later then a year later and still tight as a drum.
-Sandy
  #39 (permalink)
Old 12-19-2011, 10:28 AM
Sorry Dan. For $125k you only get the goo, not the washers and nuts. You got to ease on past the $150k mark if you want actual hardware.
  #40 (permalink)
Old 12-19-2011, 10:33 AM
Danr55's Avatar
Thanks Patrickt. Guess I'll stick with my old fashion Contemporary. I got lock nuts and lock washers and in some places, even safety wire. I guess I should feel lucky.
Dan in Arizona
CCX3209
