06-04-2014, 10:00 PM
Knock Offs???
Is it normal to be a real pain to remove the knock offs?
I have a 4 pound sand filled plastic/rubber mallet and it got the job done but is was a pain.
I think being a 15" wheel it makes it a bit tight to get a good swing at it.
Would a "lead hammer" make it easier or just less damage to the spinners.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
06-04-2014, 10:50 PM
Dan, a 6 pound lead hammer is a must. You can toss the plastic sand filled one. Many sources but here is my favorite: Cobra Valley's Muther Thumper Lead Hammer Spinner Removal Tool
This is the one I have now but it is pretty beat up: American Hammer 6 lb. Lead Hammer
Use anti-seize when you put them back on.
You will thank me.
AZ Bob
06-05-2014, 04:29 AM
DE
Cobra Make, Engine: ERA #448, 1964-427
Hey Dan, I had a hell of a time removing the spinners on my ERA when it was time to change the tires. The wheels had been on the car for 16 years and lube dry. When I up them back on I used anti-sieze grease on all mating surfaces. This also helps in tightening, it eliminates mating surface friction and gives you more tightening pressure. Now they spin off after a couple sharp hits. I recommend the anti-sieze, but, use it sparingly, you don't want silver goo coating your nice shiny wheels. Good Luck, Art Fink
06-05-2014, 06:02 AM
Helpful suggestion, soak the spinners with WD-40 and then rotate the wheel using a lead hammer..... boom off they come.
Bill
Failure is not the outcome, it's not trying.
06-05-2014, 07:01 AM
Thanks Bob
I just ordered a American Hammer like you have.
I wish I had it last night.
FFR MK1---Sold
No more Furds.
06-05-2014, 10:06 AM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Helps to also have arms like steel bands...you know, like Bob's.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
06-05-2014, 06:35 PM
I don't know, but I suspect if you leave the wheels on for a long time, it makes it really hard to take them off, especially for the first time. When I got my used Cobra the first thing I had to do was remove the tires and look around. I'm just that kind of guy..... The Cobra only had 1,700 miles in 3 years, but they were REALLY hard to remove with a lead hammer. Now it seems I'm always removing the wheels and they come off no problem. Originally there was plenty of never seize so that is not a factor.
06-05-2014, 08:37 PM
You might try this thread for more info:
Getting wheels off, whew!
-Sandy
06-06-2014, 05:46 AM
SC
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Hey DWRAT, glad you are getting the American Hammer. They work great and the company owner used to hang out here on CC.
Bob, American Hammer will rebuild that hammer for you very economically. Check their website.
Hal
06-06-2014, 07:20 AM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Regarding the anti-seize: it doesn't take much to be effective. A mechanic I knew long ago had a technique that he taught me for applications like this: "Put it on like you're trying to take it off." I've never forgotten that, and it has always worked for me.
Definitely do NOT follow the common saying, "If a little is good, then more is better" regarding anti-seize on your hubs (or any place else on a car, for that matter).
06-06-2014, 08:06 AM
Cobra Make, Engine: NAF 427
Yup. 6lb American Hammer. I use a mixture of Mobil 1 synthetic grease and anti-sieze. That's the way to go.
Greg
06-06-2014, 10:42 AM
Finish line has a special tool that might be a good investment, at 50% off, if there are any left. Personally have not used it but read several stories that made it sound like a good thing to have.
Karlos
06-07-2014, 06:41 AM
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
What is Africa not exciting enough for you that you sit by your computer??
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
06-07-2014, 01:26 PM
Always have to keep track of CC's goings on. Never know when Danr will break down again, or Ratboy might try to run someone down, or Road-Gator Mesa Mike might screw up his car, or sumpin. Went to Pretoria and then Saweto today. Heading to Victoria tomorrow where hopefully it'll be warmer.
Karlos
06-07-2014, 04:08 PM
Come on home if you want warmer...
Dan in Arizona
CCX3209
06-10-2014, 03:42 PM
Now I'm ready.
What a nice hammer.
FFR MK1---Sold
No more Furds.
06-10-2014, 03:54 PM
Ratboy, time to change your Avatar.
AZ Bob
06-10-2014, 04:29 PM
Ya, on my next outing I need to get some better pictures then my current stock.
FFR MK1---Sold
No more Furds.
06-10-2014, 05:01 PM
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
What the he!! are you doing in Africa, Karl, trying to find your roots?
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
06-11-2014, 09:00 AM
Ralphie, having a great time in Africa. Have met a whole bunch of articulate, very intelligent, hard working people. Had an upset bull elephant tire of out presence yesterday and he came 'way too close to bashing our Rover. He was "in musk" and was having his "green penis syndrome" resulting in rude behavior. Think we all can relate, on a MUCH smaller scale.
Karlos
