Old 06-04-2014, 10:00 PM
DWRAT's Avatar
Default Knock Offs???
Is it normal to be a real pain to remove the knock offs?
I have a 4 pound sand filled plastic/rubber mallet and it got the job done but is was a pain.
I think being a 15" wheel it makes it a bit tight to get a good swing at it.
Would a "lead hammer" make it easier or just less damage to the spinners.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 06-04-2014, 10:50 PM
Dan, a 6 pound lead hammer is a must. You can toss the plastic sand filled one. Many sources but here is my favorite: Cobra Valley's Muther Thumper Lead Hammer Spinner Removal Tool
This is the one I have now but it is pretty beat up: American Hammer 6 lb. Lead Hammer
Use anti-seize when you put them back on.
You will thank me.
AZ Bob
Old 06-05-2014, 04:29 AM
Cobra Make, Engine: ERA #448, 1964-427
Hey Dan, I had a hell of a time removing the spinners on my ERA when it was time to change the tires. The wheels had been on the car for 16 years and lube dry. When I up them back on I used anti-sieze grease on all mating surfaces. This also helps in tightening, it eliminates mating surface friction and gives you more tightening pressure. Now they spin off after a couple sharp hits. I recommend the anti-sieze, but, use it sparingly, you don't want silver goo coating your nice shiny wheels. Good Luck, Art Fink
Old 06-05-2014, 06:02 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Helpful suggestion, soak the spinners with WD-40 and then rotate the wheel using a lead hammer..... boom off they come.
Bill
Failure is not the outcome, it's not trying.
Old 06-05-2014, 07:01 AM
DWRAT's Avatar
Thanks Bob
I just ordered a American Hammer like you have.
I wish I had it last night.
FFR MK1---Sold
No more Furds.
Old 06-05-2014, 10:06 AM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
Helps to also have arms like steel bands...you know, like Bob's.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
Old 06-05-2014, 06:35 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I don't know, but I suspect if you leave the wheels on for a long time, it makes it really hard to take them off, especially for the first time. When I got my used Cobra the first thing I had to do was remove the tires and look around. I'm just that kind of guy..... The Cobra only had 1,700 miles in 3 years, but they were REALLY hard to remove with a lead hammer. Now it seems I'm always removing the wheels and they come off no problem. Originally there was plenty of never seize so that is not a factor.
Old 06-05-2014, 08:37 PM
You might try this thread for more info:
Getting wheels off, whew!
-Sandy
Old 06-06-2014, 05:46 AM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Hey DWRAT, glad you are getting the American Hammer. They work great and the company owner used to hang out here on CC.
Bob, American Hammer will rebuild that hammer for you very economically. Check their website.
Hal
Old 06-06-2014, 07:20 AM
Cobra Make, Engine: ERA #766, FE V8, Toploader
Regarding the anti-seize: it doesn't take much to be effective. A mechanic I knew long ago had a technique that he taught me for applications like this: "Put it on like you're trying to take it off." I've never forgotten that, and it has always worked for me.
Definitely do NOT follow the common saying, "If a little is good, then more is better" regarding anti-seize on your hubs (or any place else on a car, for that matter).
Old 06-06-2014, 08:06 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Yup. 6lb American Hammer. I use a mixture of Mobil 1 synthetic grease and anti-sieze. That's the way to go.
Greg
Old 06-06-2014, 10:42 AM
Karl Bebout's Avatar
Finish line has a special tool that might be a good investment, at 50% off, if there are any left. Personally have not used it but read several stories that made it sound like a good thing to have.
Karlos
Old 06-07-2014, 06:41 AM
dave from mesa's Avatar
Cobra Make, Engine: FFR from Levy Racing 302 FI w/Edelbrock Performer heads
What is Africa not exciting enough for you that you sit by your computer??
dave from mesa
Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes. Finally got around to going to the VA.
Old 06-07-2014, 01:26 PM
Always have to keep track of CC's goings on. Never know when Danr will break down again, or Ratboy might try to run someone down, or Road-Gator Mesa Mike might screw up his car, or sumpin. Went to Pretoria and then Saweto today. Heading to Victoria tomorrow where hopefully it'll be warmer.
Karlos
Old 06-07-2014, 04:08 PM
Danr55's Avatar
Come on home if you want warmer...
Dan in Arizona
CCX3209
Old 06-10-2014, 03:42 PM
DWRAT's Avatar
Now I'm ready.
What a nice hammer.
FFR MK1---Sold
No more Furds.
Old 06-10-2014, 03:54 PM
Ratboy, time to change your Avatar.
AZ Bob
Old 06-10-2014, 04:29 PM
DWRAT's Avatar
Ya, on my next outing I need to get some better pictures then my current stock.
FFR MK1---Sold
No more Furds.
Old 06-10-2014, 05:01 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
What the he!! are you doing in Africa, Karl, trying to find your roots?
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 06-11-2014, 09:00 AM
Ralphie, having a great time in Africa. Have met a whole bunch of articulate, very intelligent, hard working people. Had an upset bull elephant tire of out presence yesterday and he came 'way too close to bashing our Rover. He was "in musk" and was having his "green penis syndrome" resulting in rude behavior. Think we all can relate, on a MUCH smaller scale.
Karlos
