Like Tree2Likes
Old 01-14-2017, 05:59 PM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
Originally Posted by Scotchman View Post
Will the Carter pump work with a one way line to the carbs ? I do not have a return line to the gas tank.
- Yes. No return line necessary
WHOOPS - You already knew that...
- Robert
Old 01-14-2017, 08:46 PM
I use a carter in-line 15 psi fuel pump for my NOS system, stepped down to 10psi with Holley regulator and safety cut-off at 4.5 psi. If my Holley Blue ever quits again, I can steal the Carter to get me home. (Or call AAA.)
AZ Bob
Old 01-15-2017, 10:49 AM
Cobra Make, Engine: NAF 427
Depends how nostalgic or original you want to make it.
Like my SW 240A pumps, gutted and bored out to accommadate two modern electric inline fuel pumps:
Greg
Old 01-15-2017, 09:33 PM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
I can sympathize Scotty. Thinking about changing mine too. I have a Holley red back at the tank and a mechanical pump (fed by the electric pump, so in series, with a return line). The electric pump sounds like a blender. If my fuel level is below 1/4 tank I see some pressure drop if I really get into the throttle. So either the pumps aren't keeping up or I have some clogging in the filter. In any event I can't see the electric pump lasting too long based on how it sounds.
Old 01-16-2017, 11:05 AM
Karl Bebout's Avatar
Mike, don't you have FI on that monster? I've always thought they required considerably higher pressure than carbs. If the electric pump can generate the high pressure, wouldn't then running through a mechanical pump lower that pressure by restriction? My confuzzzion runs rampant.
Karlos
Old 01-16-2017, 11:07 AM
Phx Mike's Avatar
No mine is carburetor - single quickfuel 780 on a port matched edelbrock performer RPM
Old 01-16-2017, 01:23 PM
O i c
Karlos
Old 01-16-2017, 04:48 PM
Those Holley blue and red pumps (rotary vane) always are loud, especially when dead headed. They don't like it (noise, short life, vapor lock) and neither do most electric pumps. I am running a Holley gerotor with a bypass on it. Runs very quiet. https://www.summitracing.com/parts/hly-12-125/overview/
A good mechanical pump should work fine too with a carburetor. Just depends upon what poison you want.
_____________________
Old 02-02-2017, 08:38 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Default In tank
Gordon Levy hooked me up with a 345 lph in tank pump, for Mustang tank. Supports 600 hp, runs cooler and quieter. Cannot speak to reliability, only about 1500 miles on mine.
Good luck
Mark
Old 02-03-2017, 06:40 AM
55312's Avatar
I have a Holley Gerator type pump as well. 5+ years and no problems. Went through 2 vain type pumps before I tried this one. It feeds a Quikfuel 780 too.
You can still hear it but much quieter than the old red ones.
Tim
Old 02-04-2017, 08:32 AM
FatBoy's Avatar
The original 427's, including S/C and Race cars all ran mechanical fuel pumps. The twin SW pumps fitted to the S/C and Race Cobras were only for priming and reserve.
If mechanical pumps were good enough then, there's no reason to think that they're not good enough now.
Paul
Old 02-04-2017, 11:44 AM
Texasdoc's Avatar
Originally Posted by keezling View Post
If you do go mechanical, make sure you have a eccentric cam on the cam sprocket
+1
I know that mine doesn't have the cam eccentric. In many rebuilds that are planning on using an electric pump, the eccentric is not installed on the cam.
I installed a Walbro in-take retrofit pump from TanksInc. Quieter than external but still noticeable.
  #33 (permalink)
Old 02-04-2017, 12:48 PM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
My 289 was vapor locking in hot weather due to thermal soakback after starting after sitting for a short time and a very knowledgeable friend that specializes in the original Thunderbirds ( my previous car) suggested an inexpensive Carquest pump back near the tank. I switch it on for startup when cold to fill the bowls and leave it on longer if the engine is hot. If it ever vaporlocks I can switch it on to clear it. Haven't had any problems since, so far.
The Carquest pump is an Airtex E8016S and is available many places for about $25.
https://www.ctci.org/gilsgarage/VaporLock.php
  #34 (permalink)
Old 02-04-2017, 09:23 PM
CHANMADD's Avatar
I've had a blue Holley for a while now....sometimes it does get noisy, but it does go away.
Mine is dead headed, so with a return it may be quieter.
  #35 (permalink)
Old 02-05-2017, 11:18 AM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Funny, I have a Blue Holley, sometimes it's real noisy and other times very quiet, depends on how often I change my hearing aid batteries!
Ralphie, "WHAT DID YOU SAY?"
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
