2Likes
05-21-2017, 03:36 PM
Well, just shows to Goya, those of us living right, have good things happen to them, or at least minor things that could have been a whole lot worse. The flange at the back end of my drive shaft had only one bolt left holding it to the differential flange, and that was only by a few threads. Trip to ACE, some nice new grade 8 bolts and some metal insert locknuts and its a done deal. Just for grins, I'll be applying a drop of medium strength lock tight, too. Would have been an ugly job, flat on my back, but once again the investment in a lift pays off.
Karlos
05-21-2017, 04:35 PM
Good for you. I'm glad it was a simple fix.
Dan in Arizona
CCX3209
05-21-2017, 04:51 PM
Having a lift sure takes the sting out of many projects doesn't it! LOL
Flip
05-21-2017, 05:08 PM
Cobra Make, Engine: FFR1983, 427W, IRS, Wilwood brakes
Karl,
Glad it turned out this simple. The Cobra Gods smile upon you!
05-21-2017, 05:14 PM
Doc, don't get all mushy. He's just lucky there weren't any mountains around.
Dan in Arizona
CCX3209
05-21-2017, 05:20 PM
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Man that was a close one Karl. Drill some holes in them bolts and lock wire em too while you're at it :-).
05-22-2017, 06:41 AM
Cobra Make, Engine: All original, with Chevy engine since 1964
U-joints and driveshaft flange bolts are part of my annual bumper to bumper inspection-day routine...
And now, they will be part of Karl's, too
- Robert
05-22-2017, 06:55 AM
az
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
The driveshaft running out of true could have put additional load on the transmission extension housing bushing (and seal). Keep an eye out for leakage and get the seal/bushing replaced if need be. Not a big deal to do, except for pulling the trans tunnel to get at the housing. I may have the bushing puller/installer tools if they're similar in size to a top loader. I haven't seen them in 30 years, but don't think I would have gotten rid of them.
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
05-22-2017, 10:43 AM
Cobra Make, Engine: FFR MkIV 427
Got lucky for sure. Did you go buy a Powerball ticket?
05-22-2017, 03:10 PM
az
So you did have a screw loose. Happens when you get to be Karlo's age.
_____________________
05-23-2017, 10:55 AM
"So you did have a screw loose. Happens when you get to be Karlo's age."
NUTS!
No screws, just nuts.
Karlos
05-23-2017, 12:30 PM
az
NUTS!
Loose nut behind the wheel?
05-23-2017, 09:00 PM
az
Screws. Nuts. This thread is getting out of hand.
05-23-2017, 10:07 PM
Yer point?
Karlos
05-24-2017, 06:39 AM
Let's see... Grade 8 bolts, locknuts, locktight, and safety wire...?
Nah, There's nothing "overkill" about that
But if you REALLY wanted to be anal, you could also tack-weld the bolt heads to the pinion flange...
Oh, and don't forget to add a couple white nylon zip ties. Phx Mike probably has some you could use...
- Robert
05-24-2017, 08:19 AM
az
Pictures added to Facebook because CC hates me.
05-24-2017, 09:01 AM
Oh yeah like you guys don't have any zip ties anywhere! Besides I already swapped them out for some clamps I made from billet stainless alloy...
Okay not really.
05-24-2017, 11:50 AM
Zip ties, duct tape, and chewing gum... The universal tool kit.
- Robert
05-24-2017, 12:19 PM
"Zip ties, duct tape, and chewing gum... The universal tool kit."
You forgot HAMMER, BIG FU*****G HAMMER.
Karlos
