Like Tree10Likes
  #61 (permalink)
Old 01-10-2012, 07:10 PM
Philm's Avatar
Thanks Craig,
I look forward to seeing how the TKO feels behind the LS3, all part of the old school appeal.
Things get easier the 2nd or should I say 4th time round.
Phil
  #62 (permalink)
Old 01-11-2012, 12:58 AM
Merv and Sharon's Avatar
Originally Posted by sambo View Post
Where are the from gauges Phil? I like the metal housings over the plastic rebadged VDOs that are common down here.
I was thinking about the Smiths gauges when I was building, but the double cost was an issue at the time and I went with Classic Instruments as they had a huge range:
Classic Instruments Gauges from egauges.com
A very nice product, but in hindsight the Smiths are the way to go for originality.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #63 (permalink)
Old 01-11-2012, 01:21 AM
Zedn's Avatar
Gday Phil,
This build is certainly raising the bar.
That steering wheel looks like a nice piece, i haven't seen those before. Keep the updates coming.
Cheers.
Liam
  #64 (permalink)
Old 04-07-2012, 01:43 AM
Philm's Avatar
Default Orphan or fugitive
Things have been delayed with the Orphan but hopefully the painted body will be back on the chassis next week.
Here are some pics of the completed intake system.
Phil
  #65 (permalink)
Old 04-07-2012, 04:54 AM
Gav's Avatar
Gav Gav is offline
Awesome work Phil,
I love it
Powered by Cu
  #66 (permalink)
Old 04-07-2012, 09:57 PM
DaveW's Avatar
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Phil,
really enjoying your build, great ideas and finish.
Is the cap on the header a pressure relief type, or do you have a pressure relief somewhere else in the cooling system?
I'm assuming thats one of Shaun's radiators and tanks going from the TIG finish,
Dave
http://cobra-cr3514.blogspot.com/
  #67 (permalink)
Old 04-08-2012, 02:36 PM
Philm's Avatar
Hi Dave,
The cap is the return type with an recovery tank mounted in the front.
definitely shauns stuff, you cannot go passed his quality.
Phil
  #68 (permalink)
Old 04-08-2012, 05:40 PM
DaveW's Avatar
Phil,
Did you custom make the drive belt pulleys, or are they an off the shelf item, looks so much neater than the surp belt, also the waterpump is a great find for mounting the header, i assume no power steering, looks so neat and tidy, love it.
Do you have to mod the firewall to fit the inlet tubing?
Dave
  #69 (permalink)
Old 04-08-2012, 08:23 PM
Philm's Avatar
Hi Dave,
The pulleys are a sbc kit with some slight machining to make them fit.
I started with the crank pulley and custom harmonic balancer. Then milled the rear of the pump to suit then mounted the alternator.
There is an option to change the crank pulley to one with a v belt at the back and mount the powersteering pump low down.
Yes the firewayy is notched, you cannot really notice it. the dash hides most of it
the whole thing could have been so much simpler if it were mafless but this keeps it all emission complient.
Phil
  #70 (permalink)
Old 04-08-2012, 09:12 PM
DaveW's Avatar
Thanks Phil, looks great.
  #71 (permalink)
Old 04-09-2012, 03:27 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
philm
just a question where did you get your reverse water pump ,as using the gilmore drive system your water pump is running in reverse or is it a different set up that i haven,t seen on A ls2 's& 3,s
next question is when are you going to make more air intakes as i would like to purchase one & great build ; please keep them coming
ROB
not all your babies are your children
  #72 (permalink)
Old 04-09-2012, 03:37 AM
Philm's Avatar
Hi Rob,
It is a clockwize rotation pump from Stewart.
Intake factory closed down, went broke making the first one.
Phil
  #73 (permalink)
Old 04-09-2012, 05:37 AM
Aussie Mike's Avatar
Looks great Phil as usual.
I wan to know what the dry sump tank in the background is going on. Is that for Grover?
Mike Murphy
Melbourne Australia
  #74 (permalink)
Old 04-09-2012, 02:14 PM
Philm's Avatar
Neutral
HI Mike,
Yes that is for Grover, he now has a an Andra approved roll cage, reworked front suspension, a backbone stiffener and the engine cradle remade.
Needed something to do while waiting for the painter.
  #75 (permalink)
Old 04-09-2012, 04:23 PM
boxhead's Avatar
Oh Phil, Grover is going to be wild.
Cruising in 5th
  #76 (permalink)
Old 04-09-2012, 05:12 PM
That's totally nuts Phil! Should be an awesome machine when it's all together.
I would love to see more pics.
Mike Murphy
Melbourne Australia
  #77 (permalink)
Old 04-09-2012, 06:40 PM
Towmaster's Avatar
Grover Rocks!!!!!!!!
  #78 (permalink)
Old 04-10-2012, 04:51 PM
Default Vw
Phil,
One word, WOW.
STIFFY
  #79 (permalink)
Old 04-11-2012, 07:22 AM
Mando's Avatar
I thought I had to much time on my hands!
Regards.
Mando
  #80 (permalink)
Old 04-12-2012, 04:12 AM
Regards.
I wish I had too much time. Always some other insignificant job to do like fix a leaking roof at mums place or removing a bath at dads place. Parents revenge.
