January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-24-2011, 01:58 PM
Cobra Make, Engine: Cobra-less
Default New scoop?
Hi folks. I'm, trying to get my hands on a scoop for the cobra. I did try to order one through Snakebite but unfortunately they did not have any available.
We are under the pump trying to get it back on the road before christmas so any help would be very much appreciated.
Old 11-24-2011, 02:03 PM
Modena's Avatar
give the kit manufacturers a call
Ben in AU
Old 11-24-2011, 02:12 PM
David Hodgson's Avatar
Try Brian at Homebush Fibreglass in Sydney.
SLIPRY
Old 11-24-2011, 04:06 PM
There is a spray painter up here who owns a cobra and also has a mold for a scoop.
He can make the scoop in whatever you want. Polyester glass, vinylester glass or carbon.
Scoop is the same as you have pictured. Ring Glenn 0459988633
Old 11-24-2011, 04:58 PM
400TT's Avatar
You should have an update from Snake Bite today via email. Your scoop can be manufactured by Tuesday and should be able to rush it into the post the same day. All our fibreglass guys are under the pump at the moment, but we can certainly fit in a scoop for you urgently. Saw a scoop go out last week, so that must have been the last in stock.
These scoops are coming out of the same mould set used for our new Cobra body, so are exceptional quality, full gloss, perfectly straight and the shape is authentic.
www.absolutepace.com
Old 11-24-2011, 06:14 PM
boxhead's Avatar
I know Ian at Classic Revival sells them seperate, not sure if he has any "on the shelf"
Classic Revival
Cruising in 5th
Old 11-24-2011, 07:02 PM
mickmate's Avatar
I have them on the shelf if you can't get them local and it's worth shipping from the States.
mickmate
http://www.actoncustom.com/
Old 11-24-2011, 07:08 PM
Wow, that sounds great. Thank you very much for making the time. I will certainly re-confirm the order with Snake Bite if I am given the opportunity.
Thanks to everyone else for your reponses I appreciate your input.
Rate This Thread:
