questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
11-30-2011, 02:37 AM
QLD
Harrison: Commodore adjustable radius rods
One of the difficulties with the Commodore (VS) front suspension on the Harrison (and others I suspect) is that the Radius rod ("Z" bar) is not adjustable so that caster variations are difficult when wheel alignment is attempted. There are adjustable rods available and I was wondering if anyone had experience with these?
http://www.whiteline.com.au/docs/bul.../069_rr207.pdf
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Advertising
11-30-2011, 03:44 AM
VIC
Merv, I haven't set my caster yet but I was under the impression that it was done by shortening the rearward-most spacer or crush tube on the upper control arm to lay it back. Do these adjustable radius rods achieve the same thing by moving the lower arm (or its arc) forward somehow?
11-30-2011, 07:45 AM
QLD
Merv,
Like these?
Short discussion on this thread.
Geoff
11-30-2011, 12:15 PM
QLD
Yes Paul with a shimming process but Geoff where did you get those ones? That is what Fulcrum Suspensions suggested to me.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
11-30-2011, 12:40 PM
QLD
Found your source Geoff.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
12-01-2011, 11:39 PM
QLD
These are the ones that should suit Harrisons with the Commodore front end: Whiteline W82567 Front Caster correction - radius rod complete assembly
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
12-01-2011, 11:42 PM
QLD
Merv are you thinking about getting these?
Harrison Cobra
Ford 4.6l supercharged
T56 six speed
12-02-2011, 02:47 AM
QLD
Maybe. I like the idea of having things adjustable. I originally found that I had +3.5 caster each side and had this adjusted, to the extent possible, with the current set up, to +1. Car feels to have sharper turn in and does not seem to have lost straight line stability. The suspension guy I am working with suggested the adjust adjustable rods. I will keep evaluating the setting I have now first.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
12-04-2011, 02:19 PM
VIC
Merv, what problems were you experiencing with +3.5 caster? Warwick suggested something like 7 or 8 for caster, mind you I have a power rack.
12-04-2011, 10:38 PM
QLD
Paul I found the steering a bit heavy and now it is lighter and not as susceptible to road undulations.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
12-05-2011, 03:15 AM
QLD
7-8 sounds a lot, although with PS you should not feel the heaviness, but tyre wear? This is an interesting thread on caster and FF cars
Are 9.5 degrees of caster too much? - FFCars.com : Factory Five Racing Discussion Forum
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
12-05-2011, 03:51 AM
VIC
Good reading there Merv, thanks. Will probably go for around 6 degrees of caster to start with, in fact that number rings a bell rather than 7-8. It's written on a piece of paper "somewhere" after I last spoke to Warwick. I think he said zero toe front and rear as well.
12-05-2011, 03:57 PM
VIC
Just a thought - you've got some pretty lethal track weapons up there in QLD, what settings are the quicker Harrisons running?
12-05-2011, 06:31 PM
QLD
I would not classify mine in that category as it is set up as a street car. Rear camber is about +0.5 and front is about +1.20. Toe-in is minimal at the front (1mm total).
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Reason: accuracy
12-05-2011, 09:59 PM
VIC
On the CR we run the following:
Seems ot handle ok:
FRONT:
Camber 1.0 to 1.25 deg negative
Castor 6.0 to 8.0 deg positive
Toe in 2.5 to 3.0 mm TOTAL
Rgds
gregg
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
