January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 01-14-2012, 05:03 PM
Philm's Avatar
Default Waring Lights for Orphan
I am starting to get all the components ready to wire the Orphan.
I understand you need to have, a seat belt warning light and a break fail warning light.
The Seat Belt Waring light.
I am not sure what the ADR requires but I assumed you need warning light with a seat belt symbol that comes on when the ignition is first turned on.
So, then when a seat belt in the drivers seat is buckled is that when it turns off,or is a timer employed?
I will contact Klippan and see if they have a stalk that has the switch.
The Brake Fail Warning Light.
Can the hand brake and brake fail light be the same light?
Looking at our boring cars I notice that is how they are. I have the float switches on the master cylinders and a hand brake switch. If i connect these two switches to the Brake waring light on the dash will that satisfy the ADR.
Looking for guidance here.
Phil
