November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-13-2012, 04:29 AM
Peter I doubt any Cobra has an inner guard. Some have glued wet suit rubber up there to stop "stars" from appearing on the outside of the guard from tyre thrown rocks.
I've used Ute liner sprayed under my guards and in the rear where the body had a gap inside the wheel arch I've used some ABS plastic sheet. It's about 3mm thick and attached with small button head bolts (4mm) screwed into the chassis. Most plastics/perspex places can supply the abs sheet.
Rate This Thread:
