Like Tree6Likes
Old 11-19-2012, 03:40 AM
Aussie Mike's Avatar
Looks like a lot of work there Greg. I wish I'd used all the same colour filler on mine. I've had about 4 different batches now all different colours.
This is turning into an interesting thread. Keep the input coming guys!
Mike Murphy
Melbourne Australia
Old 11-19-2012, 04:54 AM
stephen low's Avatar
I assume this means Ian's mould has either done a lot of bodies and it tired or is somehow moving as I'd have thought you would all have the same sort of deviations to fill.
That doesn't seem to be the case, can anyone explain that?
I've a boat building mate that pumps out a lot of very nice gel coat finished hulls and all they need is a buff to finish off for delivery to the owners.
I know the moulds have a limited number of times they can be used before surface finish defects start to occur and it becomes more cost effective to build a fresh mould over the amount of rework needed to each new hull.
Though come to think of it the cobra bodies are multiple mouldings aren't they?.
slowy
Old 11-19-2012, 05:04 AM
I think it probably has more to do with how the parts are trimmed and then bonded together. The doors, boot and bonnet are all made from 2 skins bonded together and the doors also have the added complexity of a metal frame inside.
Mike Murphy
Melbourne Australia
Old 11-19-2012, 05:20 AM
boxhead's Avatar
Also how they are stored while curing, and in temperature extremes.
My right sill had more waves in it than the Atlantic ocean, I used a heat gunn and clamps. To pull mine back into shape.
Cruising in 5th
Old 11-19-2012, 12:37 PM
DaveW's Avatar
Heres some pics of my drivers door fit as received,
The Passenger door is a very nice fit, chalk and cheese actually.
My Passenger door is the same gelcoat as the body, the drivers door is a sickly white, suggesting it wasnt done at the same time, or possibly even a different mob.
Old 11-19-2012, 02:59 PM
Not that I really did any body preparation, perversely I have to thanks Shannons for that, but I did fit up my various panels and have to say that even the old G-Force body was pretty spot on.
I recall noting some of the filling Greg did and the only significant area was I think the centre of the driver's door and a modest amount on the tops of the guards for roundness otherwise mine was all good.
Bit of a shame to see how lax some of this manufacturing QA/QC is in this game.
slowy
Old 11-19-2012, 05:02 PM
Gav's Avatar
Gav Gav is offline
I think Dave is correct that the time/temperature or even the way the bodies are stored during the cure time has a lot to do with it.
My drivers door has the same issues as the others shown here but other than that the body/flash lines etc where not too bad.
My drivers side front wheel arch flare is not as wide as the passenger side, but that only became obvious when I modded the front brakes and the track was widened slightly.
It annoyed me at first but together with my therapist I have now gotten over it!
Powered by Cu
Old 11-19-2012, 05:21 PM
gjkrv8's Avatar
My drivers side flare etc is the same as yours Gav. I thought at first it was different camber settings but they are the same. Its one of those thing I think only the owner/builder notices. Nobody else does.
Old 11-19-2012, 07:46 PM
Default Nothing changes
Guy's,
My 1989 RMC has different rear wheel spacing ( 10mm on the right side ).
When I changed to 17" rims I should have made it 20mm as the smaller side wall
increases the gap.
As Greg states, I am probably the only one who notices.
STIFFY
Old 11-19-2012, 11:12 PM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Well if I ran the same camber left and right My right tyre sticks out side the guard my about 5-6 mm so I guess when my tyres wear down I will notice it more
Old 11-20-2012, 03:15 AM
Gav's Avatar
Gav Gav is offline
If you haven't painted yet I reckon it would be a simple fix to cut and widen the flare Alffie.
Powered by Cu
Old 11-20-2012, 03:46 AM
I have the same front guard issues. Before I bolted the body down, i made sure the front guard were even with the wheels. But the front bumper brackets were out of line with the brake vents, and the chassis touched the body at the front on one side but cleared it by 10mm on the other side. I suppose it'll behard to get the perfect body shell.
I'm so happy that i got my cobra ready painted.
JD
  #33 (permalink)
Old 11-21-2012, 02:50 AM
Nah already painted, will be one of the things I fix when I do an update, Ive looked at machining 5mm off the rim but not keen on it. Iam looking at a hard top so might adjust the guard when I paint the hard top.
Anyone fitted A/C to there cobra?
  #34 (permalink)
Old 11-21-2012, 05:06 AM
Tenrocca's Avatar
Hey Alffie, Cameron Parsons had AC on his superformance and Phil Neall is fitting it to his at the moment.
I spent a lot of time getting the body even on the chassis - measured vertically off the hubs using a spirit level to get it right - had to bend the handbrake bracket a bit to get it out of the way (otherwise when I moved it left at the back - it moved right at the front and vice versa). I reckon mine is pretty spot on now. Half the prob with bodywork is adjusting the hinges so that the least amount of work\filler will be needed to get it right. I found it a lot of fun and enjoying it all again with the hard top (although that has been put aside for a bit while I prepare for engineering in Feb)
  #35 (permalink)
Old 11-21-2012, 01:07 PM
Default A/c
Hey Alffie,
I had to put A/C into the Daytona ( Rego ) it was a pain in the arse....
Its a very tight fit under the dash and it affected the steering angles.
All I can say is good luck........
STIFFY
  #36 (permalink)
Old 11-22-2012, 03:45 AM
Very interesting thread, and I thought all that the body needed was paint, according to the ads anyway hahaha !!!
  #37 (permalink)
Old 11-22-2012, 04:07 AM
Tenrocca's Avatar
The new Pace is the best looking body out of the mould I have seen, and the latest GForce body is also supposed to be very straight. Im a little dissapointed Pace didnt have a complete car at the nats - just the body. Seems to have been a long time coming but it does look the goods.
  #38 (permalink)
Old 11-22-2012, 05:13 AM
I heard the G force display car is white gelcoat as it came out the mould !
  #39 (permalink)
Old 11-22-2012, 01:04 PM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Has anyone seen a Five Factory Body before Paint?
  #40 (permalink)
Old 11-23-2012, 01:35 AM
In their earlier videos they recommend grinding out all the body joint seams and cleaning and filling them so that you don't have release agents affecting the paintwork.
