Old 01-24-2013, 09:36 PM
bobcowan's Avatar
When I built my big inch Windsor EFI, I looked all over for a damper that I could use that already had a trigger wheel. It would have been nice to be able to use some stock components, like sensors and brackets.
But, my engine is internally balanced, with a 0 ounce balancer. Nobody makes one with an integral trigger wheel. My engine is batch fired, so doesn't need a cam signal. I ended up having a custom 36-1 trigger wheel made, and then fabbing the sensor bracket.
If course, I still needed something to drive the oil pump. My budget will definatly not allow a dry sump system, or an external oil pump. I had an old mallory distributer that I kept around for parts. I took it apart and cut it down to use as a pump drive. The cap is made from 1" copper plumbing end cap and some scrap metal.
I started out about 10 years ago with a Haltech F-10 fuel only system. I thought it was an excellent system, dead on reliable, and I learned a lot with it. Last year I got rid of it for something more sophisticated to control both fuel and spark.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Rate This Thread:
