January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree197Likes
  #41 (permalink)
Old 03-03-2014, 08:47 PM
DaveW's Avatar
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Mike,
The lathe rpm is set to 925rpm and the stock was 3/4".
The tool tip is a 7deg relief, the pack has "non ferrous" on the label, i have a heap of "Ferrous" labelled tips as well, with a 4deg relief. (obviously for steel stock)
so this combination suits the 6061 stock i'm using.
I dont usually change the speed for diameter, but i probably should
My newer lathe is sitting on 625rpm, maybe need to speed this up for aluminuim.
What do you use ?
Dave
http://cobra-cr3514.blogspot.com/
  #42 (permalink)
Old 03-03-2014, 08:50 PM
Zedn's Avatar
Dave, are you using the E38 ECU with that manifold set up or aftermarket?
Liam
  #43 (permalink)
Old 03-03-2014, 08:56 PM
Gav's Avatar
Gav Gav is offline
Hi Dave are you still going to use a FBW throttle?
Powered by Cu
  #44 (permalink)
Old 03-03-2014, 08:59 PM
DaveW's Avatar
Liam, i have an e38 and harness that i got with the engine and trans, but i have been having discussions with Wolf EMS on what to do to comply with IM240.
They have been very helpful to date.
I haven' bought anything yet, but i am leaning their way.
I will be using all the stock HSV LS3 stuff (cats, MAP, Canister solonoid, injectors, o2 sensors etc.. except for throttle body,manifold and maf.
They don't seem overly concerned about meeting this if i keep the cam sane, and mines stock at this point.
Dave
  #45 (permalink)
Old 03-03-2014, 09:05 PM
DaveW's Avatar
Hi Gav,
I little birdie tells me you have a similar or same set-up on yours, love to see some pics What did you do for injectors?
Re: DBW, i have this unit from the original manifold, and i also have the matching pedal, so if i can come up with a neat mount at the back end i will try and go this way, otherwise i'll have to look at a cable.
What did you do ?
Dave
  #46 (permalink)
Old 03-03-2014, 09:53 PM
Gav's Avatar
Gav Gav is offline
The birdie was correct
I bought new 60lb injectors with my short engine in the LS1 format.
Schwanke will make them (or have them made) in any configuration you want for about $350 a set from memory.
I run progressive twin 1000cfm throttle bodies and found that it was really hard to control wheel spin until I fitted a progressive throttle linkage aswell. But if you run FBW you can dial in the progression how you want.
I'll post some pics soon.
Powered by Cu
  #47 (permalink)
Old 03-04-2014, 02:40 AM
Gav's Avatar
Gav Gav is offline
Mando, DaveW and Zedn like this.
Powered by Cu
  #48 (permalink)
Old 03-04-2014, 03:00 AM
DaveW's Avatar
Gav,
Great pics,
did you make the linkage rod between the two quads, or is something available off the shelf.
i was going to make mine from some rose joints with left and right threads for adjustment.
Dave
  #49 (permalink)
Old 03-04-2014, 04:08 AM
Gav's Avatar
Gav Gav is offline
Locar have a selection of them.
I bought mine from VPW.
You just need to measure what size you need.
Powered by Cu
  #50 (permalink)
Old 03-04-2014, 06:24 PM
buddyg's Avatar
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
Great work! I'm amazed!
Superformance specific forum check it out!
http://spfowners.freeforums.net/
  #51 (permalink)
Old 03-04-2014, 07:27 PM
Aussie Mike's Avatar
I use 700 RPM a lot with aluminium on smaller sizes. I could run faster but the noise from the lathe gets a bit annoying. on a larger piece like a pulley I'll run about 400 RPM. Not saying those speeds are ideal, they are just what has worked for me and my lathe.
Mike Murphy
Melbourne Australia
  #52 (permalink)
Old 04-30-2014, 04:24 PM
DaveW's Avatar
Hi all,
Some more progress pics and commentary.
Firstly, made up the dual quad throttle linkage from some rose joints and alluminium rod, the ball joints are Left and right thread, for easy adjustment, but probably only do this once and never again.
My son joined a "kickstarter" program 2 years ago for the development of a 3D printer, it uses laser light to cure a resin (Stereolithography) and has very fine resolution 25 micron (0.001 inches....1 thou). This is a lot finer resolution than the extrusion printers available.
He's right into systems engineering and currently doing year 12. He just won an Australian Student Top Design Award for his "Bionic Arm" he built last year as a year 11 student, its on display at Melbourne Museum......Proud Dad moment.
Backing the project results in a printer and resins which arrived last month.
Anyway, i want in on the fun and my first part was a mounting for the MAP sensor on the CR.
There is an 3/8" NPT port on the back of the Holley manifold which would normally be used for Brake booster or Vacuum accumulator etc which i wont be using.
I designed a mount that fits over the boss with a hole in it that would then be sandwhiched in place by a 3/8" NPT bung.
The bung has a 12mm hole bored through it for the map sensor to fit into, and is held in place by a bolt into a rivnut fitted to the mount.
This is his print setup
The MAP Mount
The part still dripping after printing.
This is the assembled part after cleaning in isopropyl to remove the uncured resin.
Fitted to the manifold
All finished
I also printed up an oil cooler tube clamp to see how it would look.
I have been making my brackets from Aluminium but thought i'd see how it comes out.
The resin material has the properties of ABS plastic after curing.
I've also fitted the Radiator and Fuel Tank.
Both of these were made by Shaun Melish at Shauns Custom Alloy.
Shaun is great to deal with and his work is amazing, second to none.
Check out his website,
Custom Alloy Radiators | Surge Tanks | Oil Breathers | Manifolds | Intercoolers
At this stage, i'm now working from the front to back connecting up hoses and fittings, then onto chassis wiring and back onto making up the headers.
Dave
mate, Tenrocca, Wazza and 5 others like this.
  #53 (permalink)
Old 04-30-2014, 05:18 PM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Amazing Work, Keep up the great job.
Still drooling over the dual quad throttle bodies!!!
  #54 (permalink)
Old 04-30-2014, 05:22 PM
leroy17's Avatar
O M F G.
That looks awesome.
  #55 (permalink)
Old 04-30-2014, 05:25 PM
Dimis's Avatar
Dave I cant get enough of your posts...
That cobra of yours is really something else!
Originally Posted by DaveW View Post
Hi all,
Mate, that is both incredible and fantastic news!
Congrats to your son.
Your more than entitled to a proud dad moment on the back of that effort
  #56 (permalink)
Old 04-30-2014, 05:42 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Very nice fab work there, who ever welded that fuel tank up sure has that craft sorted out!
Looks great.
  #57 (permalink)
Old 04-30-2014, 05:59 PM
boxhead's Avatar
My car is so ****.
Cruising in 5th
  #58 (permalink)
Old 04-30-2014, 06:25 PM
Dimis's Avatar
My car is so ****.
I didn't think "COOL" was a profanity
boxhead, mate and Towmaster like this.
  #59 (permalink)
Old 04-30-2014, 06:55 PM
DaveW's Avatar
Dave, My son and I love looking at your car at the "Fest", and Gav's, Gregg's and other CR's, you can drive yours, sounds and goes great, and the pics with the Goodyears on it is awesome.
Gives me inspiration to keep pushing ahead on mine.
Cant wait till we have a CR revival......
We have at least 6 CR's on the go at the moment, all progressing at a good pace, (Ben, Phil, Brad, Dennis, Stuart, Me, Gregg's is finished).
By the way, in keeping with the CR theme you guys started, i'm going with matt body paint as well.
"from the other Dave"
  #60 (permalink)
Old 04-30-2014, 08:10 PM
boxhead's Avatar
All good guys, I love my car too.
I really think a flat paint job would be an injustice to your car though Dave.
Cruising in 5th
Rate This Thread:
