questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
197Likes
03-05-2015, 10:15 PM
Vic
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Gregg,
You cant see it in the pics, but i have laminated rubber strip to the inside of the strap, its not the usual channel type so it doesn't wrap over the edge, but is flush with strap edge.
http://cobra-cr3514.blogspot.com/
Advertising
03-05-2015, 10:39 PM
WA
Cobra Make, Engine: G-Force Mk1, LS1, T56, Jag S3 suspension
Awesome work! Coming along a treat.
03-06-2015, 04:59 AM
wa
I agree, very nice work...very inspiring and love the detail with the tank straps.....Love it when stuff like this gets posted, Thank you.
03-25-2015, 09:38 PM
Vic
Not much to report in on this month other than trial fitting the Header tank i had made.
I'm pretty happy with the "Old Skool" look.
I have a week off over Easter, I plan to finish off my headers, strip and rebuild the engine loom, and plumb the power steering.
Cheers to all.
Dave
03-25-2015, 10:00 PM
sa
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
im just awe struck its a work of art and you should be well pleased with it .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
03-26-2015, 12:16 AM
Vic
Hey Dave.
What ever happened to that eightstack intake?
Not that I have anything against your 2x4 set up.
03-26-2015, 01:22 AM
Vic
Hey Dimis,
I very very nearly bought the Kinsler 8TB Cross Ram unit January last year when i was in the states, In fact I specifically went to Michigan to look through the factory at the invitation from Brian H.
However, while touring the states, i dragged the family to Denbeste Racing up near San Fran (you got to see this place), opening day of the new Shelby factory/showroom in LV, Backdraft in Florida, and decided I liked the "old skool" look, but with all the mod cons of current technology so i went with this theme.
I still love the look of that Kinsler piece of art thou.
dave
03-26-2015, 01:24 AM
Vic
Double post, sorry folks
Reason: double posted
03-26-2015, 11:47 PM
vic
The 2x 4bbl is what all the cool kids are running Dave
Powered by Cu
09-05-2015, 03:47 AM
Vic
Hi all,
I'm still tinkering on the CR every chance i get.
Finished off all the cooling system plumbing, the headers are finished and i'm currently building the roll bar with an Aussie Mike special, (perfect bend).
I got the tyres fitted and balanced to the Dragways last time i was home and the chassis is now on the floor for the first time in over 4 years.
Another weekend on the rollbar and then its on with the body
cheers
Dave
09-05-2015, 05:29 PM
QLD
It was a long time between updates and I was wondering how this was going.
Looks good, the pusher fans are at one on these builds and the 2 x 4 setup look old school cool.
09-05-2015, 05:45 PM
VIC
Well done Dave.
I always like the Go Cart look on these Cobras. Shame to put a body on :-)
Wheels and stance look great.
cheers Gregg
09-05-2015, 09:34 PM
sa
just a question with the throttle bodies are they drive by wire or cable if drive by wire i would love a set up the same as that for my ls
09-06-2015, 12:02 AM
Vic
Deano,
I have both on the go.
At the moment its cable, but I am in the process of making a DBW mount which forms part of the rear quad spacer.
I have it designed, and just need a bit of time in the shed to machine it up.
Dave
09-06-2015, 12:44 AM
sa
awesome i will def be following your progress on this .ive been trying to think how to make a top mount throttle body work with dbw but there does not appear to be anything on the market that i can find to do the job .
09-06-2015, 05:49 AM
vic
The FBW would be great for throttle control, I have a progressive linkage to the front throttle body to delay its opening until about 20%.
Great work as always Dave!
Powered by Cu
09-06-2015, 03:39 PM
Vic
G'Day Gav.
I also designed up a progressive adjustable cable cam, with a cable from the pedal to a 1:1 ratio pulley that is locked to another eccentric lobe that pulls another cable to the throttle bodies.
At the moment its maximum reduction is 30% at zero pull to 100% at 60deg, and full open at full pedal.
Its adjustable almost back to 1:1 by rotating the Cam and lobe.
I couldn't find anything on the market like this, I will probable have a go at making it.
Dave
Its designed to suit a Lokar throttle cable end.
09-06-2015, 05:53 PM
vic
Jeezus!!! You are taking things to the next level Dave!
Powered by Cu
09-06-2015, 05:58 PM
VIC
Very nice work Dave. Reminds me of the cam setups on a compound hunting bow.
The early LS1 cable throttle bodies had an eccentric pulley on them to give a more progressive action.
Is that solid works you are using? I inquired about buying it a while back but it's about $9K but you can get the student version for about $150.
Mike Murphy
Melbourne Australia
09-07-2015, 03:08 AM
Vic
Mike, I use sketchup ver8, its free and really quick to model up parts, if i want to do serious model for CNC, or print, then i've been using Inventor, my son Tom has a student copy.
Ive played with Solidworks its similar to inventor, both have a big learning curve though.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
