451Likes
09-01-2015, 09:43 PM
SA
Dave, how much detailing do you think you can do on the block and heads, and how much of the induction will you need to remove?
Glen
09-01-2015, 11:03 PM
wa
probably just paint block and heads black, polish everything else. I am looking at adapting my standard efi to run on victor jnr efi manifold and a 4 barrel throttle body. I am working on an oval style air filter that incorporates the afm. So will have that modified look with but stock efi. I am going to reposition the coil packs to the rear of the block to hide them away. I dont even know if the standard AU intake fits under the bonnet. Would be good to know.
09-01-2015, 11:20 PM
qld
Cobra Make, Engine: Kirkham 427SC 482 Cammer
The HO 5.0 wouldn't be drastically higher so I would have thought your choice wouldn't be an issue.
09-01-2015, 11:37 PM
SA
Neutral
Going back to a V-belt?
09-02-2015, 01:30 AM
wa
not sure about V belt, maybe . I dont mind the serpentine set up though. will leave that stuff till i have a car to see where all goes.
09-02-2015, 04:12 AM
SA
I'd like to morph mine back to as period correct as I can, so I'm thinking I can certainly lose the serpentine belt....along with PS pump, A/C compressor and whatever else. All it really needs to turn is the water pump and the alternator
Glen
09-02-2015, 04:20 AM
wa
Remember you need the trigger disc on the back of the crank pulley if you want to keep the stock EFI. I will drop all the ugly p/steer ,A\C and chunky brackets.
09-02-2015, 04:13 PM
SA
It will be interesting to weigh what we take off. There must be at least 10kg there.
These are Absolute Pace cars, so we should be doing our bit with 'weight watching' as well
Glen
09-21-2015, 04:58 AM
wa
You could get the same factory GT40P heads in Alloy instead of steel and paint them engine block colour , that's my plan at moment. Thinking I will paint motor ford engine blue with polished alloy bits. Talking to Massflo it seems their 4,barrel throttle body mounted afm will work with EEC-V so that's a bonus.
10-11-2015, 10:02 PM
wa
From Hoitys which kit thread
Craig - can you clarify what your doing with the carbon fibre - Is it just basically a layer of CF layed up on the inside of the Aluminium?
We just had a nice Hail storm come through here that would have golf balled a aluminium car.
Also here are some differences between the glass car and Alloy body car
• Upgraded CNC Billet Aluminium Pushrod Suspension
• Upgraded CNC Billet Bonnet and Boot Hinges
• Upgraded Aluminium Formed Dash
• Special ALUMINA emblems and Identity Plaques
10-14-2015, 04:23 AM
wa
Heres the progress on the body buck.....still a bit away from making from panels.
My understanding is ( I could be completely wrong) the body will be lined with a CF layer making it like a hybrid alloy/CF body . This gives the body the strength so it can be removed and mounted like a fibreglass body. Might even make it more resistant to denting like traditional alloy bodies.
10-14-2015, 05:00 AM
VIC
I suspect it'll be a molded carbon fiber frame structure much like the the steel frame structure under the originals. Bonded rather than wrapped and riveted. Having a layer of CF bonded to the whole inside would make it a nightmare to repair.
Interested to see what they come up with.
Mike Murphy
Melbourne Australia
10-14-2015, 05:11 AM
wa
You could be right Mike.....
10-19-2015, 12:38 AM
Cobra Make, Engine: Pace 427
Not to mention the weight! Seems it may end up quite a bit heavier than the 'Super Street' (high carbon content) body option??? Guess time will tell. Will look cool though.
Good to see the progress though!
10-19-2015, 01:33 AM
Just to clarify a little...
You are correct Mike...
It will be "similar" to the steel frame used by other Aluminium bodied replicas, in that it will be a support frame under the Aluminium body, and of course, it will be further supported by the aluminium monocoque chassis,....but rather than steel, it will consist of a combination of Carbon and Kevlar.
Light but extremely strong, and it doesn't restrict access to the aluminium body as much as the steel frame, when the need for any work or repairs are required.
i.e. you could drill through a section of the frame if you needed to access a particular spot on the body to do a repair and so on.
If it's done right ( and that's what we're going to make sure of) it will be pretty cool and functional.
Warren.
11-30-2015, 12:30 AM
wa
Here's the buck ready to go, won't be long till Mark weaves his magic on
01-15-2016, 12:21 AM
VIC
Just saw a pic on FB of half an aluminum body hung over the Pace body buck. Looking very sexy.
Mike Murphy
Melbourne Australia
01-15-2016, 12:55 AM
TAS
Cobra Make, Engine: ?????
Can you copy it here??
The road to hell is paved with good intentions
01-19-2016, 05:08 PM
VIC
Check out Mark Nugent's Facebook page for updates. This bloke does amazing metalwork.
https://www.facebook.com/marknugent.com.au/?fref=ts
Mike Murphy
Melbourne Australia
01-19-2016, 07:22 PM
This is taking an individual cobra build to a whole new level. Congrats Dave.
