Like Tree41Likes
Old 12-30-2015, 09:16 PM
albanycobra's Avatar
Default workshop benches
I need to fit out my shed with new benches, some shelves and cabinets. Not looking for bling but practical and sturdy. Not sure if I should make or buy yet. Any ideas, links and advice greatly appreciated? I need approx 8m of bench and 6m of shelves.
Old 12-30-2015, 09:36 PM
Bill D's Avatar
I made my own work benches and bought steel shelving from Home Depot.
Old 12-30-2015, 11:33 PM
PeterAllen's Avatar
Originally Posted by albanycobra View Post
... I need approx 8m of bench and 6m of shelves.
So you'll want 24m of bench and 18m of shelves then!
boxhead and albanycobra like this.
Old 12-30-2015, 11:45 PM
Pricing up steel vs buying. I want solid, Like gearbox or half a motor solid. I also need a metal rack of some sort.....sick of stubbing my toe on SHS.....lol.
Old 12-31-2015, 12:58 AM
Gav's Avatar
Gav Gav is offline
I have fitted out my workshop with adjustable shelving that each unit is 2.7 long and 2.4 high. Each adjustable shelf will hold 200kg.
As far as benches go I have adjusted the first shelf as low as it will go, the second is at 900mm and have the top two high up giving a good work space with storage below and above.
I have fitted 1x 36w fluros to the underside of the third shelf for working light
Powered by Cu
Old 12-31-2015, 01:24 AM
Any pics Gav? I was looking at pallet stacking systems for benchs and shelving?
Gav likes this.
Old 12-31-2015, 04:09 AM
Dimis's Avatar
Grays online often has this stuff being cleared out from insolvent businesses.
Often in almost new condition and infinitely better than anything you'd find availabile for domestic applications.
GraysOnline Australia - Online Retail & Auctions
Just make sure you aren't bidding against me.
750hp likes this.
Old 12-31-2015, 01:23 PM
Bernica's Avatar
Senior CC Premier Member
Some square tubing for supports, 3/16" plate steel for bench top and a MIG welder. Maybe a plasma cutter too....
Then you can make just what you want!
I have a friend that did just that, but he made the bench top out of 3/4" plywood and covered that with heavy stainless sheet metal fabricated by a commercial kitchen contractor so was seamless and had a back splash and a return on the front. Nice touch but not cheap.
boxhead likes this.
Old 12-31-2015, 01:58 PM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Default Garage work benches
Gladiator cabinets and Benches....I outfitted my entire garage with their products. I purchased them from Sears, Roebuck. They work off a track system and can be slid along the track or moved easily to a new location...
Old 12-31-2015, 02:14 PM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Apart from Grays,Ebay sellers always have Dexion racking systems that have workbench configurations available. They have different lengths too.
www.paintwerks.com.au
Old 12-31-2015, 02:19 PM
Bernica's Avatar
These guys seem to have some nice stuff. I have been looking as well since I am going to be building a new garage soon...
http://thegarageguyz.com/wp-content/...-no-prices.pdf
Old 12-31-2015, 02:49 PM
Modena's Avatar
I also used Gladiator cabinets / benchtops, they're bling but not really "heavy duty"
They do have a welded product range which I think is considerably more heavy duty but I don' think available in Australia. It's all expensive.
Aussie Mike, boxhead, mate and 3 others like this.
Ben in AU
Old 12-31-2015, 11:51 PM
xb-60's Avatar
Dave,
I built my bench from timber offcuts from a domestic building site. Worked great as I had complete control over what I built, how big, how many shelves and doors etc.
I made the overhead shelving from timber as well, sizing to suit requirements of plastic drawers, oil containers and other bits I need to accommodate.
I've added to the shelving over the years as I've needed it, but the bench has remained 'as-built' except for the addition of some patina. Definitely no bling involved, but to my eye, it all looks purpose-built and functional. I estapol'd it all to keep it 'oil-proof'....and it still looks good (well I think so).
Glen
Edit....total cost would have been less than a slab of Pale Ale (am I talking your language?)
Old 01-01-2016, 04:05 AM
Tonus72's Avatar
Cobra Make, Engine: ?????
I went with unirack longspan.
Good value, can move it and add to it
High Quality Pallet Racking, Longspan Shelving, Factory Shelving, Wire Shelving, Pallet Jacks at everyday prices
The road to hell is paved with good intentions
Old 01-01-2016, 04:09 AM
Tonus72's Avatar
https://drive.google.com/file/d/0BzK...p=docslist_api
Not sure this will work?
albanycobra likes this.
Old 01-01-2016, 04:57 AM
Aussie Mike's Avatar
Home made angle iron bench for me. It's some heavy wall angle (about 5mm wall from memory). The top is 32mm thick MDF set into the angle with a sheet of 2mm gal bent up and laid over the top. It's been brilliant. Very sturdy and easy to wipe down if a gearbox dumps oil all over it.
If you have the time and tools you can build yourself something to fit your space.
However when I built this (about 20 years ago) there wasn't much in the way of benches available to buy. There is a huge range of them out there now.
Mike Murphy
Melbourne Australia
Old 01-01-2016, 05:04 AM
I have decided to build, I need/want solid. 75x75 steel legs. 5mm plate bench tops. will get some pics as i build them. going to dyna bolt them to floor.
Old 01-01-2016, 05:21 AM
Good stuff, It'll be a very satisfying project. I didn't dynabolt mine to the floor, just used heavy duty adjustable feet and attached to the wall via the splash back. Super stable and sturdy. Haven't felt the need to bolt it down.
If you want heavy duty how about 100mm square legs with 100x50 heavy wall C channel frame. topped of with a piece of 12mm plate. It's very heavy but awesome to weld and fabricate on. Still movable thanks to castors and adjustable feet.
The C channel makes it easy to clamp things to the top while keeping the whole thing rigid right out the the edges
boxhead, Morris, Tenrocca and 3 others like this.
Mike Murphy
Melbourne Australia
Old 01-01-2016, 06:59 AM
just when you think you're serious, someone else blows you away.....lol awesome bench Mike.......Scaled my size down to 75 x 50 x3 tube and 4mm steel bench tops and am ordering enough to 16m worth of benching.....basically down one side of the shed....with a mesh lower shelve and using 150mm x 5mm flat bar welded to back protruding up 100mm as a splash back. priced at about $1800 plus welding....
Aussie Mike likes this.
Old 01-01-2016, 11:15 AM
Bernica's Avatar
Wow Mike, that's an awesome fabricating / welding table! I made a small rolling version out of big angle and 3/16" plate with wheels so I can roll it out of the garage when I am welding. I put the tabs under the top at each end for an extra place to clamp ground if I need to ground the whole table. As heavy as it is and with all the scrap metal below, it still rolls easily. Not very pretty, but functional for me.
