Like Tree16Likes
Old 04-29-2016, 08:01 AM
Xack's Avatar
Cobra Make, Engine: West Coast Dreams
I had a bad ignition switch once. As long as it was "Ignition ON", the ignition was on. And if you held in the "START" position the starter it would crank and start. There was an open in the ignition circuit between "Ignition ON" and "START". When and if you released the starter position to spring back to "Ignition ON", it would die. You had to force it back to "Ignition ON" to keep the engine running.
Old 04-29-2016, 05:32 PM
If you are in Sydney, Pete's Custom Wiring would be able to sort it for you.. he has a shop next to Neil Streeting.
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
Old 04-29-2016, 07:46 PM
Tenrocca's Avatar
Found it finally.....
Tested the ignition switch and it was fine but it was a very good guess.
After cutting a bunch of cable ties and unwinding a couple of rolls of electrical tape I found the culprit. Had a fried joint. I think what has happened is the +12v battery wire that piggybacks off the starter had shorted out due to some of the insulation melting from the hot headers. It was this wire that had cooked the join where it is spliced into the fuse\relay module. So I was still getting 12v when I tested, but as soon as some load came on it couldn't cope and dropped to millivolts.
Thanks for all the suggestions and certainly helped me track it down.
Now to put it all back together and design a heat shield for the starter\wiring. Ill post a pic up here once I come up with something.
Thanks again everyone for your input.
Old 05-01-2016, 01:22 AM
Tenrocca's Avatar
Starter heat shield mark 1.
There are a couple of empty 10mm bolt holes in a perfect spot for this. Must be for engine mounts for another model. I've ordered some heat resistant cable sleeve to wrap the cables in as well.
Old 05-01-2016, 03:40 AM
You could also use a sheet of formable heat shield that would do an even better job for you.. no radiating from the headers..
FFR Coupe 65
Old 05-01-2016, 03:56 AM
gjkrv8's Avatar
Here's the OEM Heat Shield for the starter motor. I had this on my motor when it arrived.
You might be able to pick one up from a wrecker?
Old 05-01-2016, 06:25 AM
guye's Avatar
Originally Posted by Tenrocca View Post
...Has anyone built\designed a heat shield for the starter motor on LS engines- definately need something in there.
As Gregg said, the commodore has such a shield as standard. I retained mine and adapted it to shield my alternator, as the headers run further forward and clear of the starter.
Although on mine is was that wrinkly, double layered flexible aluminium stuff. Mine was VF Commodonor.
You can buy that flexible heat shield stuff quite easily I'm told. Haven't looked myself.
Guy
Old 05-01-2016, 06:40 AM
guye's Avatar
Here you go...
Tenrocca and gjkrv8 like this.
Guy
Old 05-01-2016, 07:10 PM
Tenrocca's Avatar
That looks good Guy, I might grab some of that formable stuff as well - I think what Ive done will make a difference but maybe not sufficient for full protection. I liked that you wrapped up the knock and Crank Pos sensors as well. What is the one into your sump for?
Old 05-01-2016, 08:30 PM
Modena's Avatar
that's the factory oil level sender
Ben in AU
Old 05-01-2016, 08:48 PM
Modena's Avatar
where can you get that foldable heat shield plate stuff?
Ben in AU
Old 05-02-2016, 12:03 AM
Aussie Mike's Avatar
Also a handy spot to put your oil temp sensor with the appropriate an adapter
Mike Murphy
Melbourne Australia
  #33 (permalink)
Old 05-02-2016, 12:05 AM
VPW sell a variety of formable heat shield panels.
Insulation
Modena likes this.
Mike Murphy
Melbourne Australia
  #34 (permalink)
Old 05-02-2016, 02:49 AM
Cobra Make, Engine: Robnell Blown LS1
You can also get it at supercheap
Platinum Heatshield Material HS1S - 700 x 290mm - Supercheap Auto Australia
