Like Tree16Likes
Old 08-01-2016, 11:10 PM
ICCARS's Avatar
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Hey Scott, I have seen those but I thought they were a bit bulky but definitely handy - the frames I use to carry the cars are easy to build out of 75x25x2.5 RHS tubing, and Dia. 4" castor wheels (swivel and brake all round).
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
Old 08-02-2016, 03:54 AM
Cobra Make, Engine: CR Cobra 3169
Even if you concrete isn't thick enough, all you have to do is run a triangle brace from the top of the hoist post to the sheds c section. That would relief a lot of pressure from the base.
JD
Old 08-02-2016, 05:50 AM
Antny's Avatar
Cobra Make, Engine: SPO 963, 351W
That ^ lift is good for a flat bottomed car like a Porsche that doesn't require access to anything in the center. But for any other car, it would probably do damage to the underside and prevent proper access. Not a good universal design, imo.
Old 08-02-2016, 02:53 PM
Dimis's Avatar
Agreed. That's why I'd go the dual in-ground scissor lift.
Also rubber blocks are used at the articulation/pick up points. So no damage is done to the underside of the car.
Old 08-02-2016, 04:13 PM
ICCARS's Avatar
I have a pneumatically operated scissor lift at home that sits outside more often than inside as it always seems to be in the way, and I don't use it that often - granted it is not an in-ground lift, so that might be a good option to consider; otherwise I would not recommend that type of lift...
Wil Escabache
ICCARS GT40 - U/C
www.iccars.net
Old 08-02-2016, 07:26 PM
Cobra Make, Engine: Harrison no. 9, Pace GT40 no. 14 build
Hi Scott, I have attached some photos of our recent shed build for reference, very similar in size to yours at 10m wide x 13m deep, 3m high walls, 15 degree pitch, I plan to install an overhead 2 post hoist, the generic brand hoist at our previous home worked well, installed it myself but had it checked over by a qualified inspector doing his rounds, the clearance to the roof is 3.9m at the post locations, concrete was thickened to suit, I also plan to put together a build trolley for the GT40 sometime soon, I feel both will be handy. All the best with the build, Derek
boxhead, Gav, schipps and 1 others like this.
Old 08-02-2016, 10:18 PM
14adrnln's Avatar
Cobra Make, Engine: Pace427 Alumina #69
Shed looks great. I was going to go barn style too but I have chosen to go wide span instead so I don't have internal posts to worry about (even though they do come in handy for power points and things).
Old 08-02-2016, 08:41 PM
Modena's Avatar
In my view the scissor lift (whether in ground or not) is only good for one thing, removing wheels. That's why they have them at tyre places. Underside access is way more important, what a waste of effort, space and money just to be able to remove your wheels?
boxhead likes this.
Ben in AU
Old 08-02-2016, 09:17 PM
Dimis's Avatar
I tend to agree BUT HOW COOL is it!
Old 08-02-2016, 10:05 PM
14adrnln's Avatar
Thanks for all your shed and hoist ideas. I am leaning maybe towards one of these Hero Hoist's as I only plan on doing the 1 Cobra build at this location (and maybe some general tyre change maintenance. I also have the shed space in another workshop only a few meters away to store it when not in use so I can maximize my floor space instead of having to park cars through and around a permanent style lift. I got my plans finalized today on the new shed and it will be 12.8m x 10m x 4m height ceiling. Hopefully that gives me plenty of room to park 2 other cars and build the cobra at the same time. Cheers Scott
Old 08-02-2016, 10:14 PM
14adrnln's Avatar
Old 08-02-2016, 10:19 PM
14adrnln's Avatar
Sorry Derek...just realised yours is not barn style and is going to be more like mine. Good job.
Cheers Scott
Old 08-22-2016, 03:03 PM
Trickcobra1's Avatar
Cobra Make, Engine: Factory five
A Lift makes all the difference. I'm about to buy another one.
Rate This Thread:
