04-16-2005, 10:02 PM
NT
Wiring harness
For those guys who have done or are doing there own wiring harness, where did you source your terminals from?
I am not going to use indivdual bullet or spade terminals at each connection and want to buy 2, 3 4 etc pind connector blocks, where can I find them?
I have some large 15 - 20 terminal connectors for passing through firewall and rear bulkhead but cant find a source for smaller connectors.
On the same subject, I realise that most of the wire harness kits are probably from the states, do you have to modify in any way since we use indictaor light instead of flashing brake light?
And do the harness's normally have an earth return built into the light systems?
Cruising in 5th
04-17-2005, 12:10 AM
vic
Cobra Make, Engine: rcm 5ltr windsor paxton supercharged
Boxhead
I can help you with your 2,3,4,6 pin plugs
they can be scorced from a motorcyclr shop in the Alice if you wish to call me on 0418538264 I can give you the details
Regards Bazz
bazz
04-17-2005, 12:17 AM
NT
Thanks Barry, calling now.
Cruising in 5th
04-17-2005, 06:01 AM
Member of the north
Cobra Make, Engine: A Cobra
Terminal Supply, Troy, Michigan.
They carry Packard weather seal and GM spec connectors, wire seals and wire.
Sorry, don't have a number.
04-23-2005, 05:14 PM
NT
I have ordered all the terminals I think I need, no doubt I will be back there to get more.
Thanks for the tip Barry.
Cruising in 5th
04-24-2005, 06:38 PM
vic
Boxhead, pm your address. I'll send you a
catalogue on all parts you may be able to use.
Regards Bazz.
bazz
