Old 09-26-2007, 04:04 AM
Default LS1 Fan Wiring + Side Indicator
Help reqired again
When wiring the LS1 motor for a single fan (not the 2 fan set up from factory) does it matter if you use the feed from the ECM for Fan 1 or Fan 2 ie does Fan 1 come on at a different temp than Fan 2.
Also what brand/make are you using for the side indicator light. The clear lens amber light Narva and Hella lights both have ugly surround mounts. I feel like bonding the Narva directly to the body and eliminating the surround altogether.
Thanks
Bruce
Rate This Thread:
