Old 06-22-2008, 12:33 AM
Merv and Sharon's Avatar
Default Wiring Diagram
I am doing the wiring on my Harrison and was wondering if anyone has a wiring diagram or description of the ignition, turn signals, hazard and head light dipper set up that Warwick uses? I think it is Ford Laser. Would make life easier with the connections to the "Painless" loom!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-22-2008, 12:59 AM
doing the column is a pain in the butt even if i have dagrams i dont use them
i get a mulitmeter and just test all the wires by switching switches and stuff
check yr engineer but last cobra i did had to have the pass lights switch working
which means when lights are off u have to be able to pull back on the lever and hi beam should turn on
this is a pain to set up cause means u have to wire up headlights exactly like factory laser then
headlights can be positive or negative triggered
i try to simplify it and always use neg trigger but then u need to use extra relays and diodes to get the pass to work
this is the most time consuming part of wiring them up the steering column
the ignition swithc should be easy
sometimes on back of switch the wires are labelled check on the black plastic where wires solder into ignition switch right behind key
my website
www.sideshowsperformancewiring.com.au
Old 06-22-2008, 01:08 AM
sambo's Avatar
Good question Merv. I'm facing the same problem with my off the shelf loom. I was planning on connecting the column's main power/ground wires to my battery (via a fuse) and using a test light to determine the function of all the coloured wires by going flicking all the switches one by one.
I believe most if not all Ford looms are colour coded the same, so if you can get hold of any Ford manual, that might be another option.
Paul
Edit: Sideshow beat me to it - nice to know my not-so-scientific approach does work!
Old 06-22-2008, 01:18 AM
Thanks. I thought that someone would have done this already and know which colours are for which function. It is Ford Laser (I have the 90's Mazda manual)? Will call warwick tomorrow to check that anyway.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-22-2008, 03:39 AM
just search the net
might take u afew days on and off but there is stuff out there
thats what i do when i need info
my website
Old 06-23-2008, 04:49 PM
Thanks again Sideshow. Most helpful, as usual. Yes it is a Laser module and with a test light I have worked out most of the connections. Also found a Mazda Protege manual (same as laser) on BitTorrents.
However, a few wires are 'left over' on Hazard and Indicator set up. On the Indicators: I suspect that FU is a common terminal for the two turn signals (TL and TR) and on the Hazard that HBA means a connection to the battery perhaps via relay and FB is the Hazard 'on' and TIG or T1G - well no idea - perhaps to ignition? On the lights plug I suspect that HU is hi beam and that HL is low beam and TNS is ?? lights on/only? and at the top of that plug HB is not needed?
Confusing stuff but getting there I guess. Got some great pics from Geof!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 05:28 PM
sambo's Avatar
Merv, is that Mazda manual small enough to email through?
Old 06-23-2008, 06:05 PM
merv,
go to the library, thay got the manuals and photo copy the diagrams.
Old 06-23-2008, 06:21 PM
Trying now - bit won't seem to load. Perhaps send me an email address?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 07:21 PM
sambo's Avatar
I've messaged it through - thanks Merv.
Old 06-23-2008, 08:02 PM
Merv & Sambo
I did this myself but I am in Texas right now and dont have the wiring diagrams to share with you however.
I got quite a bit of info off 07COB. He was bloody helpful email him.
I ended up using the painless headlight switch as the laser one got to complicated. This balanced the wiper switch out on the dash which I also used from painless The ignition switch is easy follow side shows comments. The hazard light can be used along with the indicator. There must be a range of wiring codes for lasers as I found many different ones and in the end did just what side show says but try 07COB. If not, I am back in 2 weeks and can send some photos.
Bruce
Old 06-23-2008, 08:24 PM
Could not get that thru Paul as it is 81MB! Have sent email with some advice about how to get the manual.
Getting there slowly but still with a couple of extra wires around. Tested indicators, hi beam. low beam and pass and hazard lites and they seem to work with power from a battery charger.
Relay for wipers is also under way now that I have realised that the wiring instructions from Harrisons list different colours to those on the kit for the Lucas-type motor. I have collected the coding for Lucas switches also. Is a matter of matching up the right positions hopefully.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 08:38 PM
Merv
If you have the wiper motor from Castlemain they will send you the right colour coding.
Bruce
Old 06-23-2008, 09:03 PM
I may have that one Bruce. Got it from Warwick. He is away now. Castlemaine Rod Shop?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 09:10 PM
Yes Castlemain Rod shop. Look on their web site they have the wiper motor kit listed.The trick is wiring in the return wire. They faxed me out the correct wiring diagram. Is Warrick away I have been trying to ring him.
Bruce
Old 06-23-2008, 09:58 PM
hsv300's Avatar
Hi Bruce I think Warwick is in New Zealand for the week.
Cheers Greg
Harrison Cobra
Ford 4.6l supercharged
T56 six speed
Old 06-23-2008, 10:37 PM
Thanks again Paul. I suspect that Warwick is on holidays. Hard worker that he is he probably needs it! Any chance u could fax me that diagram? (07 54482394)?
merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 10:20 PM
sambo's Avatar
This is the first I've heard of electrical diagrams from Harrison - certainly not in my build manual! Will speak to Warwick when he gets back.
Re Castlemaine's wiper kit, is that the FX-FJ or EJ-EH kit found on page 2 of this catalogue? AccessoryProducts.pdf
If not, what's the make/model that you guys are talking about?
Old 06-23-2008, 10:39 PM
Sideshow, I notice that my BA Ford Fuel pump has 4 connectors on it and I can only see a need for 2 (+ve from a relay and a ground). Question is which 2? (Part number BA935OA).
Hope this is not too much trouble.
merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 06-23-2008, 10:41 PM
sambo's Avatar
Merv, we don't have a fax here on my floor but you should be able to print that PDF from the CRS website - provided you have access to a printer.
Paul
