Old 10-05-2008, 11:30 PM
Merv and Sharon's Avatar
Default What is this?
This is a component that came on on my Mustang 302 EFI harness. I did not see it come off the original but I suspect that it may be part of the emission control system (air pump, etc) and therefore may be surplus to requirements. Any ideas? Sorry about the thumbnail pic - could not reduce it enough otherwise.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 01:05 AM
I think I can partly answer my own question now as I found the Painless manual on the harness. It is the Vacuum Regulator Solenoid (EVR). But still not sure what it connects to and if it MUST be used.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 01:41 AM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hang on.....let me get my magnifying glass
Cameron
Old 10-06-2008, 02:07 AM
I'm with Cameron. Can't see the thing.
Old 10-06-2008, 02:21 AM
this site sucks
y is it so bloody hard to post decent pics
anyway try emailing me a pic and ill let u know
otherwise get the website hosts to fuking fix it finally
hehehehehe
im over it
my website
www.sideshowsperformancewiring.com.au
Old 10-06-2008, 03:04 AM
Aussie Mike's Avatar
Originally Posted by sideshow View Post
this site sucks
hehehehehe
im over it
Mate, It's extremely easy to post decent pics on this site and there have been several threads explaining how. Try doing a bit of a search and having a read before having a rant.
The easiest way is to upload the pic to your gallery. You are best to shrink it down a bit using a photo editor program. I use 1024x768 pixels that way you will have a medium size pic and a supersize version to chose from in your gallery.
When you want to post a picture into your thread open up your gallery in another browser window. Find the pic you want and click on it so It's large size (not a thumbnail). Scroll down below the pic and you will see there is the hyperlink text all printed out for you ready to go. Select the hypertext, copy it and paste it straight into your thread. When people open your thread the hyper text automatically grabs the pic and posts it into your thread for you.
Too bloody easy.
Mike Murphy
Melbourne Australia
Old 10-06-2008, 04:33 AM
Tenrocca's Avatar
this site sucks
hehehehehe
im over it
I agree 100% Sideshow - it took me all of 5 minutes to post 50 decent size pics this morning. Completely unacceptable - you should boycott this site (or learn how to fuking use it).
Old 10-06-2008, 02:24 AM
You are a myopic lot! Will try to get a new pic posted IF I can keep it below the low kb level allowed.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 03:15 AM
You are a myopic lot! Merv
Well, my Mum did warn me, guess she was right.
Old 10-06-2008, 03:25 AM
You shoulda listened Les - actually I was wrong it is Hyperopia (can't see close things). Not sure if that gets you off the hook...
Thanks Mike I will print that advice and follow it when I can re-photo that part. Maybe a good idea to load the instructions on the website somewhere for newcomers.
Merv
Still not sure if the Vacuum Regulator Solenoid is a must?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 03:34 AM
I'm just guessing but it sounds like the purge solenoid. On the LS1 as part of it's emissions there is a solenoid valve that connects the manifold to the carbon canister. The ECU controls it to regulate the engine vacume that goes to the carbon canister to suck the fuel vapours out of it.
Mike Murphy
Melbourne Australia
Old 10-06-2008, 03:37 AM
Here's a useful thread about picture resizing and posting them into your threads.
Tips on Picture Uploads and Image Sizes
Mike Murphy
Melbourne Australia
Old 10-06-2008, 03:38 AM
You shoulda listened Les - actually I was wrong it is Hyperopia (can't see close things).Merv
Nuh, tis presbyopia Merv. ie reduced accommodative amplitude caused by advancing age and mis-spent childhood.
Old 10-06-2008, 03:42 AM
and not presbycusis also?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 03:53 AM
What did ya say?.
Old 10-06-2008, 04:17 AM
same effect for hearing...
Everyone seems to remove many the 'smog' controls (air pump system and ancillaries) from the Ford motor - just not sure which ones. I can see that some have connected the EGR vacuum line to the small vacuum on the plenum and that would seem to indicate that the EVR solenoid is not needed?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-06-2008, 04:25 AM
same effect for hearing... Merv
I know, that's why my comment was " What did ya say?. "
Old 10-06-2008, 08:39 PM
This is a pic of the Vacuum Regulator Solenoid (EVR) from the Ford EFI. I am still unsure if it NEEDS to connected.
Also there is a component that I seem to be missing: the Barometric Pressure Switch. Again, must I go hunting for that?
Merv
PS thanks for the tip re posting pics - the trick was to know to have TWO windows open at the same time!
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-15-2008, 05:07 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Merv
If your turbocharged you use a BAP, N/A MAP same component just Vac hose from the intake. You'll notice the BAP pictured has the white collar so a VAC hose won't fit on, the MAP doesn't have the collar..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 10-14-2008, 02:20 PM
Gav's Avatar
Gav Gav is offline
Side show,
I hope you are a good auto elec as you come across as nothing but an illiterate smart arse on this forum.
Gav
Powered by Cu
