  #81 (permalink)
Old 12-01-2008, 05:00 AM
No need to take everything so seriously Tomcat. 11 seconds is seriously quick.
At the end of the day your car is a kit car and so is mine. They were not made by Ford or $helby. 95% of the population probably don't know what the car is, never mind what is under the bonnet!
As you have already noted, fast times at the drag strip or circuit tend to come after plenty of practice and good setup. I hope that a few more of the Chevy guys get out and sort their cars for good times in the future.
I would be happy with 12's for my stock LS1 when I get a chance to race.
Ben
  #82 (permalink)
Old 12-01-2008, 04:10 PM
boxhead's Avatar
Originally Posted by tomcat racing View Post
hey boxhead, it happened, ive got 9 timeslips to prove it, you wanna put a little wager on it, i just dont know how to put photos on the web [ condensing them down from my camera] . thats why there are no photos of my car on here tomcat.
There are many threads with instructions on here Tom, Or if you like send to me and I will put them on for you.
Send to my email, david.rawnsley @ palya.org.au
just take th espaces away from around the @
Cruising in 5th
  #83 (permalink)
Old 12-01-2008, 04:48 PM
G'day All,
My RCM weighed in at 1180kg with 1/2 a tank and without a driver. It didn't have the twin hoops fitted and no interior trim.
Al
Originally Posted by Rebel1 View Post
Ok, found my listing of RMC cobra weights. Lowest was 1119Kg with a 302W. which I suspect is an early single rail car......then all the way up to a heaviest of 1266 Kg with an 5Ltr efi windsor. Quite beefy.
Lets say an average of 1250Kg which is some 100Kg (230Lbs) heavier than say a heavy CR (1150Kg) or some 300Lbs heavier than say a Harrison.
Tis an awful lot when you comparing apples to apples on a track.
  #84 (permalink)
Old 12-01-2008, 11:45 PM
tomcat racing's Avatar
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
hey gav, thanks for the compliment, at first i took it the wrong way , because i always thought the saying was, its not to be sneezed at', not , its nothing to sneeze at. which to my way of thinking was the opposite. then i thought s**t he must have a preeetty fast cobra if he thinks mid 11s is ordinary. tomcat
  #85 (permalink)
Old 12-02-2008, 12:01 AM
Smile time slip
hey boxhead, posting photos to email is the same problem, my wife managed to work it out several months ago when we posted a car for sale on the web ,it took her a couple of hours and i just gave up and havent tried again. ive been pretty busy but i will endeavour to learn how to do it, and you will see that time slip. tomcat
  #86 (permalink)
Old 12-02-2008, 12:15 AM
boxhead's Avatar
Nothing wrong with mid 11's Tom.
I wish I could get there, my chevy powered slug is a long way off that sort of times, I will blame tyres and driver.
Cruising in 5th
  #87 (permalink)
Old 12-02-2008, 03:25 AM
Gav's Avatar
Gav Gav is offline
No worries Tom.
Powered by Cu
  #88 (permalink)
Old 12-03-2008, 05:51 AM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Hi Tomcat
Just out interest what size tyre are you running? Are you running slicks? Jag rear? mid 11s and 121mph suggests a lot of wheel spin or to tall gears.
  #89 (permalink)
Old 12-03-2008, 07:42 PM
Smile tyres and setup 383 cid
hi allfie, on the street with my old engine [ flat tappert cam ] i use 295/50/15 radials, 26inches tall. pulled an 11.8 116mph revving to about 7000 or more with plenty of tyre spin off the line if youre not careful, same engine with solid roller revving to only 6000 rpm, i fitted a worn set of mickey thompsons et street grooved slicks 28 inches x 12.5 wide on 15s running about 14psi. they just launch you without any tyre spin , unless you load the revs right up. i dont even bother with a warmup burnout. 11.5 118mph short changing 2nd to 3rd, not using tacho. the 121mph came from holding it longer in 2nd.car setup is race built c4 auto 3 speed fully manualised with hurst shifter, jag rear end 3.66 ratio clifford locker.carby is a barry grant 850, my 60ft times arent that good because i use a edelbrock super victer intake which are not good for making torque down low, a performer manifold would be better. i wanted engine longevity and it makes all its power by 6000rpm [old engine 7200rpm] oh its spinning a cleveland crank in a windsor block with a nicely ported set of victor junior heads. it really is a very mild cam and is impeccable on the street and beautiful to drive. regards tomcat
  #90 (permalink)
Old 12-11-2008, 11:39 PM
Smile Finally uploaded photo of car and time slip!
Hi Guys, thanks for all the help, especially Boxhead with the tutorial. I have now got some photos in my gallery and a good friend walked me through it. Here is a photo of my car and that elusive timeslip!
  #91 (permalink)
Old 12-12-2008, 12:45 AM
boxhead's Avatar
Good stuff Tom, cant doubt what you see with your own eyes.
Cruising in 5th
  #92 (permalink)
Old 12-12-2008, 01:12 AM
Tenrocca's Avatar
14.14....no bad for a ford. Well done Tom.
  #93 (permalink)
Old 12-12-2008, 03:39 PM
boxhead's Avatar
You trouble maker Tenrocca
Cruising in 5th
  #94 (permalink)
Old 12-12-2008, 06:18 PM
im not biting
  #95 (permalink)
Old 12-13-2008, 12:36 AM
Tenrocca's Avatar
im not biting
Damn!!!
