Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 03-10-2012, 01:46 PM
Default Wheel and tire question
I have my rear end and rear wheels and tires taken care of. Looking to get the Team 3 AC III wheels to match for the front. Im using a set of the 5/8 narrowed tubular mustang 2 front upper and lower control arms with a set of the 11 inch brakes and rotors. What backspace and width should I use in the front as well as tire size. The team 3 guy I spoke to said 7" rim with 4.5 backspace, that sound right? I dont want the rim too far in and Id like to run a 8 in the front if possible. Also what tire size for the front.
I have these ACIII s for the rear 15x10 for my narrowed 8.8
Old 03-11-2012, 05:20 PM
It is a B+B cobra , made in 2001
Old 03-12-2012, 05:14 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I am running 4.5 back spacing both front and rear. The difference is that I have the tubular front and 9" narrowed rear. If you need, I can measure from the mounting face to the frame on both the front and rear and give you an idea if they are the same.
Old 03-12-2012, 10:45 AM
That would be cool! Thanks!
Old 03-13-2012, 12:11 PM
lnfletcher's Avatar
Ok, here's the measurements from mine.
I am running 15 X 7 and 4.5 backspace with 235/60/15 on front.
Also running 15 X 8 and 4.5 backspace with 295/50/15 on rears.
From frame to face on front is 12 7/8" and 7 3/8" on rear.
The rear is slightly tucked in on mine so it could come out a little. If you are running 10" on the rear, yours will most likely stick out a little.
I had a rub on my drivers side that I had to fix so you don't want to go farther in.
Old 03-13-2012, 06:49 PM
Wow thank you so much for doing that for me, muchly appeciated!!!
